MIXLAND Releases TILT
2022-2-6 10:20| ·¢²¼Õß: boston| ²é¿´: 1187| ÆÀÂÛ: 0
ÕªÒª: MIXLAND Releases TILTPassive tilt/shelving EQ with an adjustable modelled vacuum tube output stage MIXLAND and Kiive Audio have joined forces for TILT, which they describe as a powerful passive tilt/ ...
MIXLAND and Kiive Audio have joined forces for TILT, which they describe as a powerful passive tilt/shelving equalizer with an adjustable vacuum tube output stage. Here's what they have to say about it...
The curves and tube circuitry were modelled meticulously to provide a delicious and usable sound. The EQ section features 8 different frequency selections, linkable bands (per the traditional tilt format), and they can be unlinked for extra shelving flexibility. The user's EQ moves feed directly into the tube circuit and will influence the amount of drive and harmonic saturation that will be heard. Additionally, the user can control the amount of tube saturation using the grit parameter, and the effect ranges from subtle warmth to a sizzly clipping extravaganza depending on the amount chosen by the user.
TILT is available in aax, vst, and au formats, and is compatible with macOS X 10.7 & higher (Mojave is supported), Windows 7 & higher (Pro Tools 11 and above).
Features
Meticulously-modelled passive equalizer
Linkable EQ bands for classic tilt function, or unlink for independent shelving boosts/cuts
Delicious Class-A triode vacuum tube output stage with adjustable grit parameter
Tube stage is post EQ, and is influenced directly by EQ moves that drive into it"Tilt" parameter adds modeled tube EQ with gorgeous high and low shelves
Satisfying scale animation that reflects the amount of attenuation chosen by the user
Gorgeous tube visuals that glow brightly to convey the amount of tube warmth being appliedSatisfying scale animation that reflects the amount of attenuation chosen by the user
Available in aax, vst, and au formats
Compatible with macOS X 10.7 & higher, Windows 7 & higher (Pro Tools 11 and above) scale animation that reflects the amount of attenuation chosen by the user
Pricing and Availability:
$29.99
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
