Have you ever been annoyed by the excess of cables on your pedalboard? Because we have, and that¡¯s exactly what led us to create Puzzle Effects. As the name suggests, our pedals can slot together like puzzle pieces, allowing them to power one another and doing away with power and patch cables. The modular aspect of our concept will allow you to test different chain orders at a glance so you can easily find the one that suits you best. Also, the significant space saving on your pedalboard might create room for that one pedal that wouldn't fit in until now, who knows? We've worked hard to ensure that each of our pedals could find a place on your pedalboard, even if used alone. Indeed, their original circuitry and designs give them their own visual and sonic identity and our manufacturing methods make them durable over time. Last but not least, it is important to note that thanks to their standard jack input and output, our pedals are compatible with all other effects pedals you already own. Now that you are familiar with our concept, here¡¯s what you should know about our first line of pedals. ROCKET ROCKET is a manifestation of our love for JFET boosters, for their unmatched dynamic response and natural compression. We designed the circuitry of this pedal to capture the essence of these unique features of multiple applications. Also, its two active EQ bands will allow you to further sculpt your sound while preserving its soul. SUBMARINE SUBMARINE is a delay pedal with a deep, ambient echo. It is an ideal companion for letting your creativity run wild without worrying about repeats interfering with the notes being played. Its circuitry, based around a PT2399 chip, offers a hybrid approach that retains the natural, warm characteristics of analog signal processing, while delegating only the delay management to digital. The charm of this pedal also comes from its blend potentiometer. This approach differs from the usual ¡°mix¡± control and allows you to reach new and cavernous settings where the wet takes over the dry. BUGGY BUGGY is an overdrive emulating the roaring sensation that can be produced by a big saturated amp. Its circuitry's main feature is a ¡°charge pump¡± which increases the headroom from 9V to 18V. The saturation is thus all the more dependent on the clipping phase, ensured by two rows of two diodes in series. In practice, this results in a wide range of expression as well as an extreme reactivity to the playing dynamics and volume of the guitar. This touch sensitive pedal is therefore able to adapt to your playing and enhance the harmonics of your notes, whether you¡¯re using the neck or bridge pickup. Specifications The following specs are shared by all three pedals (unless otherwise stated): Analog effects True Bypass Power supply: DC 9V negative center (BOSS type, not included) Current consumption: 7mA ROCKET - 11mA SUBMARINE - 25mA BUGGY Designed and made in France 🇫🇷 Project Timeline Wondering how we got here? Here are the key steps of our journey: 2019: The (crazy) idea & first modeling attempts |
