Boz Digital Labs Releases FREE Panipulator 3 Audio Plugin
2022-2-6 08:01| ·¢²¼Õß: 512420| ²é¿´: 822| ÆÀÂÛ: 0
ÕªÒª: Boz Digital Labs Releases FREE Panipulator 3 Audio PluginPanipulator is a freeware tool that helps achieve accurate mix translation and it just received an update. Boz Digital Labs has updated the fre ...
Panipulator is a freeware tool that helps achieve accurate mix translation and it just received an update. Boz Digital Labs has updated the freeware utility plugin from version 2.0 to Panipulator 3.
Panipulator 3 isn¡¯t one of the most exciting freebies; it¡¯s pure utility and does its job with little fanfare. But that¡¯s in no way a negative comment because it does a very important job.
It will help you identify potential panning/phase issues and check mono compatibility across various playback systems.
Most significantly, as marked by a big red button, Panipulator 3 lets you sum your stereo mix to mono. In doing so, you¡¯ll find out if anything is lost in translation ( I also love Bill Murray and will shamelessly drop movie titles/references).
The update comes with a refreshed GUI and a new clean Lofi effect. Panipulator 3 allows you to flip the left and right channels, invert the polarity of either channel and adjust the pan law, which you can set to 0, -3, or -6 dB.
Adjusting the pan law compensates for any increase in level when two signals are summed to mono. If you have any moving elements that pan left and right, summing to mono can turn that motion into a less appealing push/pull feel. Adjusting the pan law per track with Panipulator can address that issue.
CPU-friendly is an understatement for this plugin, so if you want more than one instance, you can go as crazy as you like.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
