Saturate your signals with the Cascading FET Amplfier from British Noise Electronics The Cascading FET Amplifier is 4 channels of JFET saturation in a single Eurorack module where each one can cascade into the next ¨C this is going to get creamy. ADVERTISEMENT Cascading FET Amplifier 4 JFET amplification stages lined up side by side with individual gain and voltage-controlled feedback controls. Stage 2 and stage 4 have a Sub and Air EQ that shares the same knobs and there¡¯s a reverse switch to allow for the controls of stage 2 to be inverted. Each stage is normalised to the next to if you only plug into channel 1 you can go through 4 multiplying stages of gain and saturation and then take an output at any or all points along the way with increasing distortion. British Noise suggests doing something like plugging in a kick drum and taking out a nicely crispy sound at stage 2 with a boosted Sub and then blend with a completely distorted version of stage 4 for a bit of extra bite ¨C nice! The Sub and Air band EQ have mastering potential and you could come stages 1&2 and 3&4 to use it in a stereo mastering configuration. I¡¯ve yet to see a video or audio demonstration¡ oh hang on, what¡¯s this? Yep, that¡¯s what I thought: This thing is going to explode any signal you route to it in deliciously disastrous ways. And those LEDs really set it off. You can preorder now for ¡ê220. |
