UnitedPlugins releases "Mirror" Reverse Negative Delay Plug-in with 68%
2022-2-2 07:58| ·¢²¼Õß: holtek| ²é¿´: 733| ÆÀÂÛ: 0
ÕªÒª: UnitedPlugins releases "Mirror" Reverse Negative Delay Plug-in with 68% off intro offerUnitedPlugins has released Mirror by JMG Sound, a reverse negative delay plug-in that UP says is "first of a kind ...
UnitedPlugins has released Mirror by JMG Sound, a reverse negative delay plug-in that UP says is "first of a kind".
UnitedPlugins explains:
Mirror is a plug-in that sees the future. It reverses your audio, applies effects and plays it back before the event even begins. Mirror would automatically create the much-loved reverse reverb and snare effects in seconds, allowing you to focus on the sound, not the process.
Reverse negative delay means the reverse effect is heard before the original sound. This is achieved by reporting a fake latency to the DAW, which then compensates, aligning the end of the effect with the start of your original sound. You can also apply the reverb effect and filters before the sound is reversed.
The best way to understand and experience the effect is to grab the 15-days fully working trial version and play with the plug-in.
Mirror is compatible with the majority of VST/AAX/AU DAW applications on both Windows and macOS.
Intro Price: 22 (68% off) until the 28th of February, 2022 (Reg. 69).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
