Avantone Pro releases 800W CLA-400 Studio Reference Amplifier
2022-2-2 11:35| ·¢²¼Õß: 8546250| ²é¿´: 919| ÆÀÂÛ: 0
ÕªÒª: Avantone Pro releases 800W CLA-400 Studio Reference AmplifierAvantone Pro puts out 800W of reference-grade power with all-new CLA-400 studio reference amplifier built the old-school wayTALLMAN, NY, US ...
TALLMAN, NY, USA: picking up where it left off with its CLA-200 Studio Reference Amplifier, a 200W RMS per channel Class A/B affair developed in close collaboration with GRAMMY® Award-winning mix engineer Chris Lord-Alge, Avantone Pro is proud to introduce its CLA-400 bigger brother ¡ª built the old-school way as a classically-designed Class A/B amplifier to bring about a dynamic, high- output, high-resolution, full-range system designed to be paired with large passive monitors demanding the highest amounts of power ¡ª as of February 1¡­
As alluded to by its ¡®numerical¡¯ nomenclature, the CLA-400 can generate over 400W per channel into an 8¦¸ load, lending its use as a perfect fit for medium to large passive monitors in a studio environment where its standard 3U (483mm W x 133mm H x 487mm D/19¡± W x 5.25¡± H x 18¡± D) rack-mount chassis conveniently comes into its own. Of course, the CLA-400 clearly warrants pairing with large passive monitors that demand the highest amounts of power that it is duly designed to deliver from the ground up.
Ultimately, then, the CLA-400 is a dynamic, high-output, high-resolution, full-range system built the old-school way ¡ª as a classically-designed Class A/B amplifier. As such, Avantone Pro paid particular attention to creating an amplifier in the traditional studio style, with ample analog VU (Volume Unit) meters, high-quality Japanese components, and a serious toroidal transformer linear power supply, as well as implementing a classic bipolar transistor design delivering a robust bottom end. Extremely low distortion, steady performance under harsh conditions, and open and transparent sound attributes all combine to make the CLA-400 an obvious choice for discerning studios seeking serious dynamic range.
Notable no-compromise components notwithstanding, it is worth noting that the CLA-400¡¯s convection-cooled design makes for silent operation. So since there is obviously no fan noise involved as a result, it can reside in the same location as the passive monitors to which it is providing power ¡ª perfectly suited to installation in studio control rooms, in other words. Indeed, it is designed to be used in a studio environment requiring high power output with no fan noise.
Needless to say, the CLA-400 capably delivered a powerful 400W into 8¦¸ under test conditions, while it is also worth noting that it can run at one third power without thermal fault ¡ª findings borne out by its impressive tech specs: 8¦¸ stereo power (1kHz): 360W; 4¦¸ stereo power (1kHz): 540W; 8¦¸ bridge power (1kHz): 760W; slew rate (at 1kHz): 28V/us; input sensitivity (1kHz): 0.775V (0dBU); Total Harmonic Distortion (1kHz): <0.1%; intermodulation distortion (at 10% rated power 1KHz): <0.1%; crosstalk: -70dB; frequency response: 20Hz-20kHz +/-0.5dB; frequency response: 20Hz-20kHz +/-0.5dB; input impedance: 20K¦¸ (balanced)/10k¦¸ (unbalanced); damping factor(100Hz, 8¦¸): 250; signal-to-noise ratio (A Weighted): >103dB.
Time to make some room in a suitable studio rack and make an attentive return to passive monitoring, maybe? After all, Avantone Pro puts out 800W of reference-grade power with its all-new CLA-400 studio reference amplifier built the old- school way, weighing in at a reassuringly solid 22.2kg (49lb)!
The CLA-400 is available at Avantone Pro¡¯s US Dealers (http://www.avantonepro.com/us-dealers.php) with a MAP (Minimum Advertised Price) of $1,199.00 USD. (European SSP ¡ª Suggested Selling Price ¡ª is
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
