Cool WAV releases free "Simple Console" Plugin for Windows VST3
2022-8-5 12:17| ·¢²¼Õß: 8324360| ²é¿´: 1204| ÆÀÂÛ: 0
ÕªÒª: Cool WAV releases free "Simple Console" Plugin for Windows VST3Cool WAV has announced the release of Simple Console, a free VST3 plugin for Windows.Simple Console has some of the features found in an ...
Simple Console has some of the features found in an analog console. This plugin can be used on the first insert of every track on your mix, except for the Master. Add some drive (preamp saturation) for each track to bring warmth and glue. Cut the low/high frequencies of your melodies using the filters. Gain stage with the input/output knob.
Features:
Filters: High Pass filter from 20.0hz ¨C 300.0hz Low Pass filter from 6.0kHz to 20.0kHz.
Input: Gain before going through the Saturation circuit. Range is -10db to 10db. The knob is stepped by 1db.
Drive: 0 to 100% Be careful going past 85% it gets really intense. This is the same as Simple Saturation.
Output: Gain after going through the Saturation circuit. Range is -10 to 0db. The knob is stepped by 1db.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
