Accentize Chameleon2 - Automatic Reverb Matching
2022-8-4 10:31| ·¢²¼Õß: robko| ²é¿´: 1371| ÆÀÂÛ: 0
ÕªÒª: Accentize Chameleon2 - Automatic Reverb Matchinghttp://www.accentize.com/chameleonChameleon is an intelligent audio plugin which uses artificial neural networks to estimate and model the exact reverb ...
Chameleon is an intelligent audio plugin which uses artificial neural networks to estimate and model the exact reverb content of any source recording. You can build a reverb profile in seconds and easily apply it to dry studio recordings.
After the initial release about a year ago we have received a lot of user feedback and suggestions. The new version has an overall improved workflow along with a new Profile Library which lets you easily organise all your reverb profiles. Additionally, the automation possibilities have been refined.
The upgrade from Version1 to Version2 is FREE. Your existing license will continue to work.
Chameleon2 will not replace your existing Chameleon installation and can be installed and used together with Chameleon1.
Please note that Chameleon2 is only available with iLok authorisation. In case you are still using your serial key based license please convert it to iLok for free. You will find more information on that under the Support tab on our website.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
