Slate Digital FG-DS 902: dbx 902 De-Esser Emulation for your DAW
2022-6-20 07:58| ·¢²¼Õß: engine| ²é¿´: 1674| ÆÀÂÛ: 0
ÕªÒª: Slate Digital has taken on the challenge to emulate the classic dbx 902 de-esser and released the FG-DS 902 plug-in for Virtual Mix Rack. Slate says that the FG-DS 902 plug-in delivers the same organi ...
Slate Digital has taken on the challenge to emulate the classic dbx 902 de-esser and released the FG-DS 902 plug-in for Virtual Mix Rack. Slate says that the FG-DS 902 plug-in delivers the same organic and natural sound as the original. How does it compare to other alternatives?
The dbx 902 came out in the early 80s and remains one of the most popular analog de-essers to this date. One of its advantages is that it doesn¡¯t use a fixed threshold. Instead, it determines the required amount of de-essing by comparing the levels of the selected frequency and the full bandwidth signal. As a result, the de-essing is independent of the input level, which ensures musical and transparent processing.
The new FG-DS 902 plug-in from Slate Digital brings this classic de-esser to your DAW. Like the original, it lets you dial in any frequency between 800 Hz and 8 kHz. The mode switch, which toggles between the regular wide-band mode and a high-frequency mode, is also available. The range control serves to set the desired amount of de-essing (e.g. how much attenuation should be applied to detected sibilances). There¡¯s also a virtual LED meter for displaying gain reduction.
Added features
In addition, Slate Digital has come up with a couple of features that weren¡¯t available on the original. Instead of the bypass switch, the FG-DS 902 plug-in offers a mix knob for blending the processed and dry signals. There¡¯s also an output level control, which helps with gain staging. And last but not least, Slate has added a button for previewing the affected portion of the signal, which is great for precise adjustments.
Just a few months ago, Lindell released its version of the 902 with many clever additions, so it¡¯ll be interesting to see how the Slate FG-DS measures up ¨C especially since it¡¯s quite a bit more expensive.
Price and compatibility
The Slate Digital FG-DS 902 plug-in is available through the Slate All Access Pass subscription (which also includes about 75 other plug-ins), but you can also purchase the plug-in by itself. A monthly All Access subscription is USD 14.99 with a one-year commitment (USD 9.99 during the first six months). The month-to-month plan with no commitment is USD 24.99/month. If you pre-pay for a whole year, you pay USD 149. The perpetual license for the FG-DS 902 plug-in is also USD 149.
The plug-in runs on macOS 10.14 or higher and Windows 8 or 10 in AU, VST, VST3, and AAX formats (64 bit). For the All Access Pass, you¡¯ll need an iLok account or dongle. Caution: The perpetual license requires an iLok 2 or iLok 3 dongle!
https://slatedigital.com/fg-ds/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
