Plugin Alliance has announced the release of an update to its bx_masterdesk, a complete high-end analog mastering system in a single plugin. Incredibly easy to use, and with several major upgrades to the original from 2018, the new bx_masterdesk True Peak aims to further improve your workflow and sound. When bx_masterdesk first came out, it was PA¡¯s best-selling plugin of the year, and BX has just managed to take things a step further! The upgraded bx_masterdesk True Peak is still so easy to learn though, even musicians can quickly dial in great-sounding masters. Add some tastefully curated chains of some of the best-sounding mastering processors to your sound! Thanks to a freshly updated GUI and improved algorithms, bx_masterdesk True Peak even easier to use and delivers even better results! In addition to revamping the GUI, the engineers at Brainworx have added the most frequently requested features from fans of the original masterdesk. This streamlined all-in-one mastering solution now includes the limiter algorithm from bx_limiter True Peak¡ªknown to be one of the most musical sounding True Peak Limiters ever made. Its updated Input and Output Meters now precisely show True Peak level, while the TMT circuit is now switchable between analog and digital modes, and the compressor mix range has been extended to run a full 0% to 100% wet. bx_masterdesk True Peak features High-end analog mastering chain in a single plugin Simple 3-step workflow and clear intuitive metering Now includes the limiter algorithm from bx_limiter True Peak Updated True Peak meters show intersample peaks. Improved GUI for even easier control. Fully variable Compressor Mix control, from 0% to 100%. Extensive preset list for immediate results. New Mid/Side (M/S) features for fail-safe stereo enhancement. TMT ¡ª Brainworx patent-registered ¡°Tolerance Modeling Technology¡± (US Patent No. 10,725,727). bx_masterdesk True Peak is on sale for the intro price of $199.99 USD instead of $299 USD. Use coupon code MASTER14999 at checkout to get it for $149.99 USD until July 10th, 2022. Owners of the original version can get bx_masterdesk True Peak for $19.99 USD. The plugin is included at no extra cost in the MEGA Bundle and MIX & MASTER Bundle, and it is also available for $1 USD in the Forever 29 plan. Çë¿´½éÉÜÊÓÆµ£ºhttps://youtu.be/cjykpbCZO9s |
