SirenFX NoisePalette Free plug-ins SirenFX NoisePaletteSometimes a bit of noise is all you need! NoisePalette by SirenFX delivers noise in a wide variety of flavors. Using a spectral tilt filter, you can dial in the precise spectral roll-off to generate red, white, and pink noise, and anything in between. There¡¯s also a simple attack and release envelope. SirenFX says that the resulting noise works great for sound effects, and you can use it as a starting point for all sorts of synthesis experiments. NoisePalette is a VST3 and AU plug-in for Windows and macOS. However, the developer says that it doesn¡¯t currently work in Ableton Live, due to that DAW¡¯s inability to load instrument plug-ins without a MIDI input. They¡¯re working on a solution. https://www.sirenfx.io/l/Sfnp https://youtu.be/VV-6Mi4cySo |
