| Uhhyou FDN64Reverb Free plug-ins Uhhyou FDN64ReverbJapanese developer Uuhyou is back with yet another unique plug-in. FDN64Reverb is a reverb based on a feedback delay network (FDN), similar to the excellent Valhalla Supermassive. You can adjust a bunch of delay parameters and apply modulation to the delay time. Moreover, there¡¯s a pair of high and low cut filters, and even a rotation effect for extra movement. Don¡¯t be put off by the technical-looking GUI ¨C Uuhyou¡¯s plug-ins are excellent sound design tools! FDN64Reverb is currently available for Windows and Linux as a VST3 plug-in. https://ryukau.github.io/VSTPlugins/manual/FDN64Reverb/FDN64Reverb_en.html |
