NAMM 22: Rubber Band Compressor Updated Snappy compressor plug-in is rebuilt from the ground up
2022-6-9 12:32| ·¢²¼Õß: joeslin| ²é¿´: 814| ÆÀÂÛ: 0
ÕªÒª: NAMM 22: Rubber Band Compressor UpdatedSnappy compressor plug-in is rebuilt from the ground upMIXLAND has announced that the Rubber Band Compressor is back and rebuilt from the ground up, with the hig ...
MIXLAND has announced that the Rubber Band Compressor is back and rebuilt from the ground up, with the highest fidelity sound and more features than ever before. They say that the original Rubber Band VCA circuit has been reimagined with their newest modeling technology, in order to provide greater feel, bounce, and resolution, with instantaneous load times.
A spokesperson told us, "We've taken the original concept of our emulation of what happens when a physical rubber band is stretched (tension-based compression with an exponential ratio that snaps back harder depending on how far you push it), and pushed it to its limits."
New features include an FET mode, expansive crunch circuit with adjustable tube bias, type, and, high and low shelving with selectable frequencies, flexible sidechain options, artist presets, A/B comparison modes, an "undo" and "redo"  features, pre-and-post EQ modes, mix knob, TAPE and LIMIT functions, and three overall voicing modes (vintage, flat, and modern).
Rubber Band Compressor v2 is available in aax, vst, and au formats, and is compatible with macOS X 10.7 & higher (M1 & Monterey are supported), Windows 7 & higher (Pro Tools 11 and above).
Features
Fully-reimagined build of the classic Rubber Band dual stage VCA compression circuit (with exponential ratio that pushes back the harder you dig in)
All new FET mode, expanding the versatility of the world's snappiest compressor
Adjustable shelving equalizer with flexible frequency points
New "Vintage" "Flat" and "Modern" modes to add the right flavor to any sound it touches.
New Tape Saturation and Limiting functions adding a new level of both vibe and functionality.
"Weight" mode triggers a highpass to the compressor's detection circuit,for musical low end response.
Available in aax, vst, and au formats.
Compatible with macOS X 10.7 & higher (M1 and Monterey supported), Windows 7 & higher (Pro Tools 11 and above).
Pricing and Availability:
Rubber Band Compressor v2 will be available for purchase for $49.99 starting on June 3rd 2022. Owners of the original Rubber Band Compressor will be able to purchase v2 with a 50% discount voucher. A 14 day trial will be available, so users can demo the plugin before purchase.
https://www.mixland.io/online-store/Rubber-Band-Compressor-V2-p468133673
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
