DontCrack releases Nomad Factory Bus Driver plugin (free for limited time) DontCrack has announced the release of Bus Driver, a vintage optical compressor plugin by Nomad Factory for Windows and Mac. Nomad Factory Bus Driver Bus-Driver is an optical compressor that provides a wide range of compression effects, reminiscent of the best vintage compressors made in the ¡®60s. Compression is one of those studio processes that is all too often taken for granted and not usually used to its full potential. Today¡¯s producers think nothing of inserting compressors on every single channel of their DAW when mixing, but old school engineers had to learn to make the most of only a few units of compression and this made them learn them inside out to use them to their best advantage. Bus Driver is modelled on the classics from the ¡®golden age¡¯ of tube compressors. Also included in Bus Driver is a Tube-Driver Saturation feature. It allows you to add the sound of a vintage tube amplifier giving you the differing electronic characteristics of triode, tetrode, and pentode vacuum tubes. So you can add the vintage warmth of the those models of the classic tubes (e.g. ECC83, 12AX7, etc..) to your tracks or on your mix bus. Nomad Factory designed an Output Stage Soft-Clipping to eliminate digital clipping at any output level and produce a smoother distortion characteristic. This feature is in addition to the Tube-Driver Saturation Modeling included in Bus-Driver. The plugin is available for download for free for a limited time, in gratitude to the audio community for the help Bernie Torelli received in his fight against cancer. Sadly, Bernie passed away January 18th, 2016. Read more here. Use voucher code freebusdriver at checkout. |
