Blind Audio releases Connection ¨C Modular Arps sample pack Loopmasters has introduced Blind Audio¡¯s latest sample pack Connection ¨C Modular Arps, featuring 100 soaring arpeggiated synth loops created within the confines of a single modular synth patch. The loops included are provided dry with no pre-rendered effects, perfect for all kinds of house, techno, or just about any type of electronic dance music. Blind Audio¡¯s 100 Series sample packs aim to bring you a focused set of sounds that serve a very specific purpose in your productions. Each pack includes 100 loops, all created using a single sound source: be it a synthesiser, instrument, modular patch, drum machine, etc. The sounds included are presented raw and unaffected ¨C embrace the flaws, noise, and quirks of the original machines. Modular Arps is priced ¡ê9.95 GBP. |
