Silver - Volume I is an additional Volume for Silver. IMPORTANT: It is mandatory that Silver be installed on your computer for the additional volumes to be used. Make sure you have installed and authorised the Silver FREE player through the Aquarius Desktop application. About Silver Silver is a suite of Acqua plug-ins consisting of three FREE players available in the following formats: VST, VST3, AAX, and AU and dedicated to emulating reverbs of physical spaces and sampled equipment. Silver is an amazing project that has taken a long time to design and develop and has paid off considerably given the incredible results obtained, in fact we have finally given birth to a new generation of cutting-edge reverb plug-ins. What you get Silver - Volume I includes 3 different emulations from a vintage Analog Reverberator under the name/category 'Corn'. This rare, hard-to-find, vintage solid-state reverb offers a pure 50s/60s sound. Don¡¯t expect a warm, tubey vintage reverb though, it is quite the opposite. For this reason it is pretty special and rightfully deserves to be added to Acustica¡¯s collection of sampled reverbs. Excellent for running in front of a dirty amp sound to get loud sounds and a great sonic ¡®flavour¡¯ . If you¡¯re looking for Phil Spector¡¯s extreme ¡®Wall of Sound¡¯, with huge walls of electric guitars laden with reverb and distortion give this reverb a shot, it will really surprise you how much it can make a difference. With Silver Volume I you have access to an emulation of this incredible reverb! NOTE: In addition to the intrinsic characteristics of the reverb, thanks to Acustica¡¯s technology you can also appreciate the harmonic distortion component of the unit in this emulation. In the ¡®Spaces category¡¯ there are available (under the menu voice 'Corn') 3 different emulations according to the desired reverb sound (Dark, Bright,Flat). Under the ¡®Preset category¡¯ there are 3 different choices according to the reverb sound/parameters (Dark, Bright,Flat).. NOTE To facilitate the understanding of the hardware emulations, when possible, we use the usual convention, so we have chosen compound names that include an apparent reference to the released 'Acqua plugin'. This should aid in the identification of the original sampled unit. None of Silver's Volume H emulations are part of already released products. They are samples of hardware not included in the plugin suites currently released by Acustica. Click here to download all Audio Demos IMPORTANT To install correctly any Silver Volume is mandatory to install the Silver FREE first. 1- Log-in on the Aquarius Desktop application using your user-name email and your password. 2- Verify that Silver FREE is updated to the latest release (mandatory step). 3- Type the product name on the search page, and the Aquarius Desktop application will find the Silver Volume I. 4- Click on the install button. 5- Select the correct plug-in format for the installation from the drop-down menu. 6- Click on the install button. 7- Aquarius Desktop application will download, install, and authorize the commercial product automatically. Remember to update Silver Player before to install additional packs and if you have already installed Volume A, remember in order to: 1- Update Silver Player 2- Update Silver Volume A 3- Install Silver Volume I Other extra Volumes/Packs will be released soon. For further details, consult the Silver user's manual in the Overview section. HOW TO TRY A PLUGIN: TRIAL MODE Create a user account (if you do not have one yet) on our website Download and Install Aquarius, our products manager, for either macOS or Windows. Log in to Aquarius using your user email and password. Type the product name in the search field inside Aquarius to find the '(trial)' versions of the product, then click on the thumbnail or the 'Install' button. This will take you to the product pages (the trial versions of a product are also visible in the 'related products' section on the right) Select the right plugin format according to the DAW you are using and click 'Install.' Aquarius will download, install, and authorize the trial product automatically. Run your DAW. You're set! For details about the installation/authorization process, please refer to this page. Technical Specs Available sample rates: 44.1kHz | 48kHz | 88.2kHz | 96kHz M1 Compatible |
