ElephantDSP.com Room Reverb
2022-4-18 10:43| ·¢²¼Õß: sonivox| ²é¿´: 814| ÆÀÂÛ: 0
ÕªÒª: ElephantDSP.com Room ReverbElephantDSP.com Room ReverbRoom Reverb by ElephantDSP.com is just what it says: an algorithmic room reverb with plenty of tweakable parameters. The open-source plug-in gives ...
ElephantDSP.com Room ReverbRoom Reverb by ElephantDSP.com is just what it says: an algorithmic room reverb with plenty of tweakable parameters. The open-source plug-in gives you precise control over the early reflections, reverb tail and stereo width. There¡¯s even a couple of interesting parameters such as spin and wander, which you won¡¯t find on most other reverbs. I also dig the clear and uncluttered GUI ¨C let¡¯s hope that this is only the beginning and that we¡¯ll also see other reverbs like hall and plate in the future.
Room Reverb is currently available for Windows and Linux (64 bit, VST3). A version for macOS is in the works.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
