GuitarML updates TS-M1N3 Tube Screamer guitar pedal effect to v1.1.0
2022-4-18 10:15| ·¢²¼Õß: sonivox| ²é¿´: 709| ÆÀÂÛ: 0
ÕªÒª: GuitarML updates TS-M1N3 Tube Screamer guitar pedal effect to v1.1.0GuitarML has released an update to the TS-M1N3 effect plugin, a clone of the TS9 Tube Screamer overdrive guitar pedal from Ibanez.Ma ...
Machine learning was used to train a model of both the drive and tone knobs for an accurate recreation of the pedal in all possible configurations. This plugin uses two conditioned parameters during model training to recreate the entire device using machine learning, as opposed to snapshot models at a particular setting. For best results, use prior to amp -> cabinet -> reverb effects to fully simulate playing an overdrive pedal through a physical amplifier.
Changes in TS-M1N3 v1.1.0
Added AAX format to Windows/Mac Installers.
Added Linux .deb installer.
Added LV2 format for Linux.
Added internal samplerate converter for consistent sound across samplerates using a single neural net model.
TS-M1N3 is now available to download for Windows, Mac and Linux, as standalone software and in VST3, AU, AAX and LV2 plugin formats.
https://guitarml.com/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
