MAXBAX : New Age by Analog Obsession
2022-4-11 12:32| ·¢²¼Õß: jeassy| ²é¿´: 885| ÆÀÂÛ: 0
ÕªÒª: https://www.patreon.com/analogobsession Support for free VST2, VST3, AU for WIN & MAC
Here is MAXBAX! (Formerly MASBAX)
Fully passive Baxandall eq with extra Mid band!
FEATURES
- LOW: 20-30-40-60-85-120Hz with stepped boost/cut (0.5dB)
- MID: 0.2-0.4-0.8-2-4-7kHz with stepped boost/cut (0.5dB)
- HIGH: 9-13-16-20-27-40kHz with stepped boost/cut (0.5dB)
- OUT: +/-6dB with stepped boost/cut (0.5dB)
- LR/MS: Dual Mono or Mid/Side processing
- LINK: Will link L and R
Version 1.2
- Fixed audio drop/cut caused by Mid Band
Version 1.1
Version 1.0 - Initial release
Available Formats
VST/VST3/AU | Mac 10.9 - 11.X
VST/VST3 | Windows 7 - 8 - 10
Download Links;
Mac
Windows
Windows Zip
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
