United Plugins launches Bassment multi-effect bass amp by Muramasa
2022-4-11 08:42| ·¢²¼Õß: jeassy| ²é¿´: 717| ÆÀÂÛ: 0
ÕªÒª: United Plugins launches Bassment multi-effect bass amp by Muramasa United Plugins has launched a new audio plugin by Muramasa Audio. Following the recent Electrum guitar amp and pedalboard plugin, Bas ...
United Plugins has launched a new audio plugin by Muramasa Audio. Following the recent Electrum guitar amp and pedalboard plugin, Bassment provides bass guitar players with a similar amplifier and multi-effect solution.
Of course, Bass is the fundament of music. And when guitarists got their Electrum, we simply had to create Bassment. We built a multi-effect all-in-one one-screen bass solution around the most flexible bass amp that was ever made. An amp that contains them all. You wish you could have this beast on stage. Dream on, it won¡¯t happen. But you can still use it to get the most of your mixes.
The flexible amp plugin features a 5-band EQ, dedicated compressor for low-end, 15 types of cabinet simulations with 15 alterations (over 200 models), smart input level, EQ matching, reordering of modules, multi-modulation, parallel saturation, advanced tuner, and more.
Bassment comes in VST/VST3, AU and AAX plugin formats for Windows and Mac. It is on sale at an introductory 85% discount, priced 19 EUR instead of 129 EUR for a limited time. You can try the plugin with a free trial version.
Bassment is available to purchase at the United Plugins store and from distributors Plugin Boutique and ADSR Sounds.
https://www.unitedplugins.com/Bassment/
https://www.pluginboutique.com/product/2-Effects/53-Multi-Effect-/8897-Bassment
https://www.adsrsounds.com/product/software/united-plugins-bassment-multi-effect-bass-amp-plugin/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
