X Audio Systems BEATS FM: Stereo processor and radio infused noise generator
2022-4-10 09:41| ·¢²¼Õß: shengwen| ²é¿´: 724| ÆÀÂÛ: 0
ÕªÒª: X Audio Systems BEATS FM: Stereo processor and radio infused noise generatorX Audio Systems are about to launch a new BEATS FM prototype onto Indiegogo to nail down ¡°The Ultimate Noise Machine¡± ster ...
X Audio Systems are about to launch a new BEATS FM prototype onto Indiegogo to nail down ¡°The Ultimate Noise Machine¡± stereo sound processor that¡¯s also a radio.
BEATS FM
The name makes you assume it¡¯s an FM Synthesis-based groove box, but it really isn¡¯t. No idea where the Beats come from but the FM refers to the integrated FM/AM/SW radio that can be used as a noise source. In some ways, the radio is a weird distraction from what is otherwise quite an interesting stereo audio processor. On the other hand, the radio seems to be a big part of this box and so it must be a thing.
This video will help explain it, possibly.
The project was started in 2020 and at this point, they are about to release revision 4 of the prototype. It¡¯s going to be crowdfunded via Indiegogo and you are advised to sign up now to make sure you get the early-bird discount. You can follow the evolution of the project via the @mad_synth_engineer TikTok or Instagram.
Processing
The BEATS FM unit contains a wideband FM/AM/SW radio with manual and LFO modulated tuning. It also takes an external input that you can mix with the output of the radio. Next, we have a pair of analogue lowpass and highpass filters. Following on is a stereo digital delay with up to 4 seconds of delay time. The modulation section has a very interesting LFO. Along with rate, there¡¯s a multiplier knob to reach a wide range of frequencies. But this has 16 LFO waveforms and all of them can be bent and manipulated via a Wave Bender knob.
Sync is also a feature. You can tap in a tempo, send it audio clicks or clock pulses and that can be used to keep the LFO and delays in check.
Here¡¯s an example of using the radio to generate some analogue FM synthesis.
View this post on Instagram
A post shared by mad_synth_engineer (@mad_synth_engineer)
BEATS FM is a really interesting project that just as a desktop audio processor could be a lot of fun. The radio aspect is undoubtedly a fascinated way to get audio and noise flowing that¡¯s ever-changing and prone to difference, so I can see where that could come in. I¡¯m looking forward to seeing more complete demos of the unit once it¡¯s ready to go.
X Audio Systems webpage.
BEATS FM Indiegogo page.
X Audio Systems BEATS FM (rev3)
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
