Space Brain Circuits MidiVolts Desktop is a new compact MIDI to CV interface with 4 voice polyphony, different voicing modes & more. MIDI is one of the most ingenious inventions. It allows us to control and play synthesizers with external controls or even with the DAW. Whether hardware or software, you can¡¯t avoid MIDI. If you work with modular synthesizers like Eurorack, CV and gate come into play. And for incorporating MIDI in your modular synth, you need a signal converter. Already in 2021, Space Brains Circuits published a compact MIDI to CV interface with polyphony. Space Brain Circuits MidiVolts Desktop The MidiVolts Desktop is a portable card-format MIDI to CV interface. The interface creates up to four voices from one MIDI channel. For each voice, you get a dedicated CV and gate output. Thus, you can work with polyphonic patches with up to 4 voices. They operate on the 1v/oct standard for Eurorack and most hardware synthesizers. MidiVolts Desktop features 6 different voice control modes: mono, duo, unison, poly 3, poly 4, and CC giving a lot of voice flexibility. Further, it also includes a handy MIDI to clock output conversion as well as options to customize your SysEx MIDI messages. The unit requires a 9V center positive power supply which is not included. Attention, it¡¯s positive and thus most ¡°negative¡± guitar pedal power supplies don¡¯t work here. Here is a demo video showing how you can play a Moog Grandmother Synthesizer in polyphony. At first sight a very useful MIDI to CV interface. Especially considering that a Keystep or controller can only do monophonic M to CV. Here you get four voices, which is very practical for poly setups. Space Brain Circuits MidiVolts Desktop is out now for 169,09 |
