HY-Plugins releases HY-Filter4 for Windows, macOS and Linux VST2, VST3 & AU
2022-3-28 10:29| ·¢²¼Õß: 7856890| ²é¿´: 790| ÆÀÂÛ: 0
ÕªÒª: HY-Plugins has release HY-Filter4 for Windows, macOS and Linux in VST2, VST3 and AU format.HY-Filter4 is a semi-modular type effect plugin.It contains multi-engine filter + built-in 38 effect units + ...
It contains multi-engine filter + built-in 38 effect units + 10 types of modulators + the CTRL SEQ.
You can modulate parameters of the main filter, built-in effects and modulators by using the modulation units.
In addition, these are controlled by the CTRL SEQ which is a grid sequencer.
Features:
Multi-engine filter.
38 built-in effect units.
10 types of modulator (total 42 units).
Built-in grid sequencer (CTRL SEQ) for controlling effect and modulator units.
Drag and drop modulation assignment.
Intro Price: $38 until 15th March, 2022 (Reg. $55).
https://hy-plugins.com/product/hy-filter4/
* It's a free update for owners of HY-Filter2/HY-Filter3.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
