HoRNet Butterfly: Mastering processor and versatile channel strip HoRNet Plugins has announced the release of its new mastering processor and versatile channel strip HoRNet Butterfly, an effect plugin designed to give you the tools for the final touches for your stereo mix or for mastering. The plugin features the same high quality processing modules found in the SAMP master processor for Dolby Atmos. Packaged into a single plugin you can find: an equalizer (using the same technology found in our TotalEQ) a compressor (using the same technology of our SyncPressor) a clipper and a limiter (using the same technology of our Magnus MK2). The order of the effect can be rearranged dragging their position in the top tabs control section and in the left part of the interface you can find a handy LUFS metering section that shows you the input and output levels with the standard ¡°momentary¡±, ¡°short term¡±, ¡°integrated¡± and ¡°true peak¡± readings. While we designed the plugin to work on stereo busses there is nothing that prevents you from using it on mono channels transforming it into a powerful channel strip. HoRNet Butterfly for Windows and Mac (VST/VST3, AU and AAX) is available now for 37.99 EUR. You can try the plugin with a free demo version. |
