Free EQ And Saturation Plug-In Mixlands FreeTILT! is a tilt equalizer with adjustable vacuum tube output stage
2022-3-16 07:53| ·¢²¼Õß: musicians| ²é¿´: 859| ÆÀÂÛ: 0
ÕªÒª: Free EQ And Saturation Plug-InMixlands FreeTILT! is a tilt equalizer with adjustable vacuum tube output stage Free EQ And Saturation Plug-InMIXLAND and Kiive Audio have joined forces for a free plug ...
MIXLAND and Kiive Audio have joined forces for a free plugin, freeTILT! This is what they have to say about it...
This tubular beauty is a stripped down version of the TILT! plugin, another dreamteam collab between Mixland's Jesse Ray Ernster and Kiive Audio's Eddie Lucciola! FreeTILT! is a powerful passive tilt equalizer with an adjustable vacuum tube output stage. The EQ curves and tube circuitry were inspired by classic and modern pieces of tube gear, and various aspects of those boxes were modeled and mangled at an exceptionally bizarre level of precision to provide a delicious and undeniably-pleasing sound. The tilt knob boasts (you guessed it) tilt functionality with fixed high and low frequency points at 100hz and 12khz, and the user's EQ moves feed directly into the tube circuit and will influence the amount of drive and harmonic saturation that will be heard. Texture for days, baby! Additionally, the user can control the amount of tube saturation using the grit parameter, and the effect ranges from subtle warmth to a sizzling clipping extravaganza depending on the amount chosen. The GUI is inspired by Jesse Ray's Los Angeles mixing room, MIXLAND, featuring the Strauss Elektroakustik MF-4 monitors.
Features
Meticulously-tuned passive equalizer with an analog sound
Classic tilt functionality with high and low shelving points at 100hz and 12khz
Delicious Class-A triode vacuum tube output stage with adjustable grit parameter
Tube stage is post EQ, and is influenced directly by EQ moves that drive into it"Tilt" parameter adds modeled tube EQ with gorgeous high and low shelves
Satisfying scale animation that reflects the amount of attenuation chosen by the user
Gorgeous tube visuals that glow brightly to convey the amount of tube warmth being appliedSatisfying scale animation that reflects the amount of attenuation chosen by the user
Available in aax, vst, and au formats
Compatible with macOS X 10.7 & higher (M1 and Monterey supported), Windows 7 & higher (Pro Tools 11 and above) scale animation that reflects the amount of attenuation chosen by the user
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
