Fugue State Audio Spectral Lemuring Fugue State Audio Spectral LemuringFugue State Audio says that Spectral Lemuring is inspired by Spectral Monkeyage by Shiny FX, a long discontinued freeware plug-in. It¡¯s a spectral processing effect that lets you process the high-magnitude and low-magnitude parts of the FFT signal separately. If that sounded too technical, Fugue State Audio says that it can be thought of as a lo-fi pitch shifter with some extra functionality. It¡¯s not the same as Spectral Monkeyage, but it does some of the same things. Spectral Lemuring is a VST3 plug-in for Windows. |
