Behringer 2-XM, a replica of the Oberheim Two-Voice analog Synthesizer in Eurorack SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks! Behringer 2-XM is a replica/clone of the legendary Oberheim Two-Voice analog poly Synthesizer with a 32-point patch bay for Eurorack. Last year in October I reported on a PCB photo of a new Behringer Synthesizer. It wasn¡¯t official then, but there were many points in favor of an Oberheim Two-Voice replica in Eurorack. This is now confirmed. Behringer announced the 2-XM today, a clone/replica of the Oberheim Two-Voice analog Synthesizer in Eurorack format. Behringer 2-XM According to the Behringer FB post is the 2-XM an authentic reproduction of the SEM 2-Voice circuitry from the ¡®70s. One speaks here of an analogue polyphonic Synthesizer because one has two equally equipped SEM voices. They give you a pure analog signal path with in total 4 VCOs, 2 multi-mode VCFs, 2 LFOs, 4 envelopes, and more. There are different play modes available: poly with two voices, a split mode with one voice on each side or with 4 oscillators in unison mode. The 2-XM is based on two Oberheim SEM module replicas that have all the features known from the original. Each voice has two oscillators with sawtooth or variable pulse waveforms and a sync option for sharp lead sounds and complex effects. Plus, it hosts a noise generator. Then, you have a recreation of the legendary Oberheim SEM filter with morphable lowpass, high-pass, band-pass and notch modes. Modulation side, you get two ADS envelopes (VCA/VCF) and an LFO for adding life and movement to your sound. Always keep in mind, you get all this twice as you have two identical SEM module replicas. Patch It With its 2-XM, Behringer takes the semi-modular route and makes it fully Eurorack compatible. So next to the 2-channel mixer with level and pan controls for stereo sounds, you get a patch matrix with 16 inputs and 16 outputs. This gives you a maximum flexibility and allows you to integrate the SEM sound in you Eurorack synth. There are also two external inputs for processing external sound sources. It also comes with a portamento function that is applicable to both voices making pitch gliding effects possible. Backside The backside is different from the other Eurorack synths. Here you can find a stereo output on two 6.3mm sockets giving you a true stereo signal. Further, it has a MIDI thru socket with a MIDI matrix, a USB port, and a power supply input with a on/off switch. Behringer says it comes with a MIDI and USB implementation with MIDI channel and Voice Priority selection. The MIDI input port is on the front panel as usual. If you want more voices, no problem. You can poly chain up to 16 devices giving you up to 32 voice of polyphony. If you take the targeted price into account, you would have to pay $4784 for 16 units , so not that cheap anymore. Availability They say the product is fully developed and once they will receive the semiconductor chips, the will start the production and sent it asap to the retailers. Very interesting at first sight. One of the clones/replicas I¡¯ve been waiting for. I can¡¯t afford an original one, so there¡¯s a good chance I¡¯ll put one in the studio. And thanks to the modular factor, it is much more versatile than just a simple keyboard version. Behringer 2-XM will be available soon for a suggested price of $299 USD. |
