StudioHub Introduces ¡®World Panel¡¯
2022-3-8 22:49| ·¢²¼Õß: vargo| ²é¿´: 796| ÆÀÂÛ: 0
ÕªÒª: StudioHub Introduces ¡®World Panel¡¯Universal Interface facilitates connection of personal audio devicesAngry Audio¡¯s StudioHub Universal Interface ¡ª aka ¡°World Panel¡± ¡ª is for broadcasters who n ...
Angry Audio¡¯s StudioHub Universal Interface ¡ª aka ¡°World Panel¡± ¡ª is for broadcasters who need to put audio from personal devices on the air.
¡°This 1 RU stereo device provides convenient interfaces for multiple types of I/O, enabling quick connection of nearly any kind of audio gear to your mixing console,¡± it said in its announcement.
Analog inputs on the front include balanced +4 dBu on two XLR/TRS combo connectors, unbalanced ¨C10 dBV on two RCA (phono) jacks, and one 3.5 mm stereo jack. Analog outputs are stereo +4 dBu balanced on two XLR connectors, ¨C10 dBV on two RCA jacks and a 3.5 mm stereo jack.
[Check Out More Products at Radio World¡¯s Products Section]
¡°In addition to the stereo outputs, there are two analog balanced mono outputs on XLR connectors. These are summed L+R and are intended to feed reporter ¡®press box¡¯ recording devices. These outputs are switchable between line and mic level with a ground-lift function. All analog signals are electronically buffered with high-performance active audio circuitry.¡±
For digital audio, AES/EBU inputs and outputs are provided on XLR connectors as well as S/PDIF inputs and outputs on RCA/phono coax connectors. ¡°All digital signals are electronically buffered and transformer coupled.¡±
The front also features two pass-throughs: a USB and an RJ45 port. These fit into standard ¡°D-type¡± cutouts and are easily changeable to different connector types.
The rear panel uses the StudioHub+ wiring standard for analog and digital audio connections to and from the user¡¯s console. Power comes via an included external power transformer. The Universal Interface is enclosed in a powder-coated steel chassis, with no exposed circuit boards.
Retail price is $595.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
