Digital Brain Instruments releases vPlayer 3 - Free Simple VST/AU Host
2022-2-22 07:10| ·¢²¼Õß: 63487880| ²é¿´: 917| ÆÀÂÛ: 0
ÕªÒª: Digital Brain Instruments releases vPlayer 3 - Free Simple VST/AU HostDigital Brain InstrumentsDigital Brain Instruments has released vPlayer 3, a new version of the standalone software application fo ...
Digital Brain Instruments has released vPlayer 3, a new version of the standalone software application for macOS and Windows developed for quick testing new VST/AU instruments without the need to use any DAW.
vPlayer 3 is also ideal for playing a quick loading jam session with your friends using your favourite virtual instruments, playing up to 4 instruments at same time using 1 to 4 different MIDI keyboards.
Features:
Play up to 4 VST/AU instruments at same time.
Load 1 VST/AU effect plugin on each instrument output.
Use up to 4 different MIDI keyboards.
Load and save presets.
Master EQ.
Recording up to 192kHz.
What's new in vPlayer 3:
Improved audio engine.
Improved preset system.
Improved recording system.
Support for VST3.
Support for Apple M1 computers.
vPlayer 3 is a free download at digitalbrain-instruments.com/freebies
Read more at
www.digitalbrain-instruments.com
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
