HoRNet Plugins introduces: HoRNet SAMP the "virtual" master bus for Dolby Atmos
2022-2-20 22:07| ·¢²¼Õß: 53013790| ²é¿´: 1056| ÆÀÂÛ: 0
ÕªÒª: HoRNet Plugins introduces: HoRNet SAMP the "virtual" master bus for Dolby AtmosHoRNet Plugins introduces: HoRNet SAMP the quot;virtualquot; master bus for Dolby Atmos-unnamed-9-.jpgHoRNet SAMP is a pr ...
HoRNet Plugins introduces: HoRNet SAMP the "virtual" master bus for Dolby Atmos-unnamed-9-.jpg
HoRNet SAMP is a processor designed by the Italian engineer Antonio Porcelli to work with Dolby Atmos mixes and resolves one of ¡°problems¡± that engineers find when approaching this new format: there is no master bus. This big difference with conventional stereo mixes makes it impossible do to any of the classic adjustment you do on a stereo mix.
Imagine you have 128 different tracks and you want to lift the ¡°highs¡±, you should go one by one and adjust the EQ, SAMP resolves this issue by providing four classic master bus processors that are linked together, so a change on an instance of SAMP is reflected on every other instance, simultaneously.
Packaged into a single plugin you can find: an equalizer (using the same technology found in our TotalEQ) a compressor (using the same technology of our SyncPressor) a clipper and a limiter (using the same technology of our Magnus MK2). These processors take the audio from each track and apply the same settings to every track, simulating the effect of a master bus processor.
Of course the plugin can also work in any traditional DAW as mono channel strip!
HoRNet SAMP is available now for just 59,99
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
