There¡¯s something brilliantly odd about a tongue drum emerging from a wooden enclosed delay effect box ¨C let¡¯s get tinkering. Tongue Drum Delay I do like a good tongue drum. Like the Handpan it has an ethereal quality that can take you to other worlds. Probably why it works so well as a backdrop to Minecraft. Anyway, here¡¯s a tongue drum squished into a box that acts as a delay effect for some very cool melodic and thoroughly engaging sounds. The box has a built-in record function that you can loop on playback which is then routed through a delay effect. You have control over the speed of playback and so the pitch of the sound. What you get is a deliciously simple and fascinating music generator that you could play for hours. It has an audio output for integrating into your larger setup, a pitch control knob, two knobs for the delay, an infinite loop switch and even a slot for your beaters. Simply and beautifully made and available now for $400 at BrandNewNoise Instruments & Audio Recorders. |
