Impact Soundworks Releases Bass Sculptor Multi-FX plugin
2022-2-17 09:41| ·¢²¼Õß: 5601290| ²é¿´: 711| ÆÀÂÛ: 0
ÕªÒª: Impact Soundworks Releases Bass Sculptor Multi-FX pluginImpact Soundworks has released BASS SCULPTOR, a native VST/AU/AAX plugin designed to get your bass in shape! Whether it¡¯s fattening up weak dru ...
Impact Soundworks has released BASS SCULPTOR, a native VST/AU/AAX plugin designed to get your bass in shape! Whether it¡¯s fattening up weak drums, smoothing out a bass guitar recording, cleaning up mud, or tightening up a whole mix, this plugin gives you all the essential tools for managing low end in one convenient interface.
https://impactsoundworks.com/product/bass-sculptor/
The plugin features four distinct sound modules working in harmony: a subharmonic generator, a stereo imager, a surgical EQ with adjustable band & highpass filter, and a bass compressor. Any component can be quickly toggled on and off, and each has just the right amount of tweakability: enough to shape your sound, without being overwhelming.
Plus, with clean, precise, and innovative DSP by Jatin Chowdhury, Bass Sculptor does exactly what it says in the name without stressing your CPU.
No matter what kind of music you create, Bass Sculptor and its versatile set of factory presets will help deliver an even cleaner, smoother, and all-around better final mix.
Four Bass Processors
Subharmonic generator: True synthesis of sub-frequencies based on the input signal; not just a simple pitch-shifter or octaver
Bass Imager: Collapses low frequencies to mono using one of three processing modes, ideal for making club-friendly mixes
Bass EQ & Filter: Surgical high-pass and single-band EQ with both minimal and linear-phase modes
Bass Compressor: Highly-responsive compression of bass frequencies at up to 10:1 ratio
See it in action
Dry/Wet Audio Demos
https://soundcloud.com/isworks/sets/bass-sculptor-demos
Availability
Bass Sculptor is available now for $59, and comes in VST3, AU, and AAX formats. Copy protection is a simple one-time, dongle-free challenge/response using a serial number. Offline activation is also supported!
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
