Slowslicing Cyberia Slowslicing CyberiaThis funky bitcrusher plug-in looks like it came straight out of lain, the anime series. It¡¯s got everything you¡¯d expect from a hard-hitting bitcrusher, and then some. You can of course adjust the bit depth and sample rate, and there¡¯s a smoothing option. Cyberia also includes a resonant multi-mode filter, adjustable dithering and mix and output gain sliders for applying just the right amount of the effect. If you¡¯ve ever wanted to crush bits anime-style, here you go! Cyberia is available for Windows, macOS and Linux as a VST3 plug-in. |
