Symphony Desktop February 2022 Release - All Apogee FX Rack Plugins
2022-2-3 12:55| ·¢²¼Õß: 430680| ²é¿´: 870| ÆÀÂÛ: 0
ÕªÒª: Symphony Desktop February 2022 Release - All Apogee FX Rack Plugins on Hardware DSP - Apogee ElectronicsApogee Electronics¡¯ February 2022 software release for Symphony Desktop delivers the ModEQ 6, M ...
Apogee Electronics¡¯ February 2022 software release for Symphony Desktop delivers the ModEQ 6, ModComp and Opto-3A plugins to the hardware DSP on Symphony Desktop.  You can now use and control the complete suite of Apogee¡¯s 6 Hardware DSP DualPath plugins directly from the touch screen. Symphony Desktop is the only audio interface that lets you record, monitor, mix and master using the Apogee hardware DSP on your interface and the same native plugins in your DAW ¨C no audio interface hardware required.
What Do you Get with Symphony Desktop?
Hybrid DSP/Native Plugins + Superior Workflow for Recording, Monitoring & Mixing
Symphony Desktop is designed to work with a full suite of plugins for recording, mixing and mastering.
6 Hardware DSP plugins are included with Symphony Desktop
Symphony ECS Channel Strip ¨C EQ, Compression and Saturation
Pultec EQP-1A ¨C Program Equalizer
Pultec MEQ-5 ¨C Mid-range Equalizer
Opto-3A ¨C Vintage Compressor/Limiter
ModEQ 6 ¨C Modern 6 Band Visual Equalizer
ModComp ¨C Modern Visual Compressor/Limiter
All of the Hardware DSP plugins are free when you register your Symphony Desktop and install the firmware. You can control Hardware DSP plugins from the Symphony Desktop touch screen and print and monitor through FX for zero latency recording.
2 Native plugins are included with Symphony Desktop
Symphony ECS Channel Strip ¨C EQ, Compression and Saturation (hardware DSP/native plugin)
Clearmountain¡¯s Spaces ¨C Bob Clearmountain¡¯s Personalized Reverb Spaces (native only plugin)
The Symphony ECS Channel Strip is a DualPath plugin allowing you to unlock the powerful hybrid DSP/Native plugin workflow that is unique to Symphony Desktop. With hybrid plugins you can print from hardware DSP or record/monitor from your DAW without printing using hardware DSP/native plugins. And you can run Apogee hybrid plugins natively in your DAW while you mix ¨C no hardware required.
Get 50% off the Complete Apogee FX bundle for Symphony Desktop
When you purchase Symphony Desktop, you can get the entire suite of Apogee FX DualPath native plugins at a 50% discount and unlock the complete hybrid DSP/Native plugin workflow. Customers that already have the Apogee FX bundle can get 50% off premium Clearmountain Series plugins as well (Clearmountain plugins are native only).
Learn more about 50% off plugins promotion
Workflow that Works for You
With Symphony Desktop, the Apogee Control Software and the Apogee Channel FX plugin, you can set up a variety of workflows that offer low-latency recording, maximum CPU efficiency, easy collaboration and the option to print or just monitor plugins in your projects. Plus, you can use Apogee plugins with or without Symphony Desktop connected to your computer.
DSP + Native Plugins for Hybrid Recording
Apogee¡¯s hybrid DSP workflow approach addresses the specific challenge of low-latency recording in a way that does not impose restrictions. The DSP plugins running on the Symphony Desktop are only engaged to provide near-zero latency monitoring on the tracks currently being recorded, but after recording the tracks, seamlessly switching to native plugins running on the computer in your DAW allows you to scale your session to the huge track counts that are typical in modern music production.
What¡¯s New in this Release
Symphony Desktop (firmware update required- included in this release)
New hardware DSP plugins
ModEQ-6
ModComp
Opto-3A
System Requirements
macOS 10.14.6 or later
Mac Intel and M1 processors
Windows 10 20H1 or greater
PACE iLok Account for Apogee Control 2 software and Apogee plugins
AAX Native, AU (Mac Only),VST or VST 3 Compatible Host Application
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
