PlugSearch 3 - Search Plug-Ins in Logic Pro The days of digging down in Plug-in menus in Logic Pro are over. PlugSearch allows you to do a text-based search, and automatically inserts the Plug-In in a split second. And with version 3, PlugSearch is the worlds first tool that automatically categorises all your Plug-Ins. Get your free 30 day trial here: https://speakerfood.com/pages/plugse...3-product-page https://www.youtube.com/watch?v=ciSrKI6NyfI KEY FEATURES • Text-based Plug-in search • Search by Plug-in manufacturer or category • Hide Plug-ins from search results • Insert double-mono or mono to stereo Plug-ins • Remove Plug-in from insert slot by key command • Custom assignable key commands • Plug-in usage statistics • Installed Plug-in statistics • Plug-in Manager • Automatically launches at login NEW IN VERSION 3 • Automatic categorisation of all Plug-ins • Improved search window • Quick Load for first empty Plug-in slot • User defined favourites with dedicated shortcut or MIDI CC message • Plug-In info panel • Google, YouTube and manufacturer quick links • Art Conductor Pro Articulation Set search • Support for MainStage 3 • Support for Selection-based Processing • Universal key command for search, remove & quick load • Automatic updates • Option to show original name for Plug-ins with a custom name • Support for Japanese and Chinese • Automatically hide unauthorised UAD Plug-Ins |
