Live 11 Release Notes
2022-2-3 11:44| ·¢²¼Õß: volunter| ²é¿´: 729| ÆÀÂÛ: 0
ÕªÒª: Live 11 Release Notes11.1 Release NotesPlease note there is no automatic software update for 11.1. Check out this article for information on manually updating Live.New features and improvements:Native ...
11.1 Release Notes
Native Apple Silicon Support
Live 11.1 adds native support for Apple M1 computers.
Arrangement View Improvements
You can use the left arrow key to navigate from an automation lane or take lane to the main track, this will fold the lanes as well. You can also use the left arrow key to navigate from tracks in a group to the main Group Track.
The Arrow Left/Right shortcut has been added to the Arrangement Track Title Bar info text. The shortcut folds/unfolds the track.
The Arrow Left/Right shortcut has been added to the Toggle Additional Automation Lanes info text. The shortcut folds/unfolds additional automation lanes.
Browser
A new Devices icon has been added to Live¡¯s Browser:
When viewing Sets in the browser, you will see a Devices icon for device chains on a track that contain at least one device.
When you expand a Live Set in the browser, either from the Current Project folder, Templates folder, or a folder of Sets you have added in Places, you can unfold the tracks in the Set to reveal their device chains. These chains can then be moved into the current open Set using drag and drop or by double-clicking on the chain. The Device settings from the original Set are retained but any previously recorded automation is not.
Capture MIDI
In the first captured MIDI clip (in an empty set with the transport stopped), if the detected loop is eight bars or less, the first played note is considered the start of the loop.
When only one note is played in the first captured MIDI clip (in an empty set with the transport stopped), the loop boundaries are set to the note start and end, and the tempo is accordingly calculated, resulting in a one, two, four, or eight bar loop. This is particularly useful when playing a rhythmical sample with a single MIDI note.
In Session View, new captured clips now use the ¡°Adaptive Grid: Narrow¡± setting instead of ¡°Fixed Grid: 1/16.¡±
Clip View
Added responsive Clip View options:
In Clip View, all clip properties are now displayed in panels/tabs instead of separate panels. Clip View properties can be arranged vertically by moving the mouse cursor to the left from the Clip View panel edge next to the Sample Editor/MIDI Note Editor.
Clip View properties can also be arranged automatically, which switches between the horizontal and vertical views depending on the height of the Clip View area. Select ¡°Arrange Clip View Panels Automatically¡± from the View menu to enable this option.
When Clip View panels are arranged vertically, the individual tabs (e.g. Clip, Audio, Envelopes, etc) can be collapsed and expanded using the arrow icon to the right of the tab header.
When Clip View panels are arranged vertically, the individual tabs (e.g. Clip, Audio, Envelopes, etc) can be folded/unfolded using the Arrow Left/Right keys.
Sample information for audio clips (e.g. sample name, sample rate, etc) is also displayed in the Clip View and appears differently in the vertical/horizontal view modes.
Clip View panels can now be accessed using keyboard shortcuts. In MIDI clips, ALT + 1 switches to the Notes panel, ALT + 2 switches to the Envelopes panel, and ALT + 3 switches to the Note Expression panel. In audio clips, ALT + 1 switches to the Audio panel and ALT + 2 switches to the Envelopes panel.
Clip View can be toggled to its maximum height using the keyboard shortcut CTRL+ALT+E (Win) / CMD+OPT+E (Mac) or the View menu entry ¡°Expand Clip Detail View.¡±
The chosen Responsive Clip View mode is now saved in Live¡¯s Preferences.cfg file.
When multiple audio clips are selected, the sample properties (sample rate, bit depth, and channel count) for all samples will be displayed in the Clip View. If a value is not the same for all samples, the character ¡°*¡± will be displayed. In Clip View, you will also see the total number of samples selected.
The Pitch dial is now smaller and the Gain slider has been enlarged.
When switching between panels in Clip View using the keyboard shortcuts ALT + 1/2/3, the panel header that was switched to will be selected.
If Clip View is arranged horizontally when Live is first opened and either the Audio or Notes tab is selected, the corresponding panels in both audio and MIDI clips will remain unfolded when switching to Clip View¡¯s vertical arrangement.
Comping
You can now duplicate selected take lanes using the keyboard shortcuts CMD + D (Mac) / CTRL + D (Win), or by right-clicking on the take lane header and selecting ¡°Duplicate.¡±
Changing the color of a clip in a take lane changes the color of the corresponding clip in the track¡¯s main lane and vice versa. Splits are created on the updated clips in certain cases when the relation between other highlights on different clips change.
The horizontal lines that separate multiple take lanes match the color of the clips that are in those lanes.
When renaming multiple tracks or take lanes using the context menu option, you will see the edit field when you right-click on a track or take lane.
Control Surfaces
When navigating between devices on a selected track with the PreSonus ATOM SQ, you can now scroll between devices by holding the navigation buttons down.
If an invalid CC, note, or channel value is used in a UserConfiguration.txt file, the associated User Remote Script can still be loaded.
Core Library
Frequency Shifter presets are still available in Core Library/Devices/Audio Effects/Legacy/Frequency Shifter
CPU Meter
The CPU meter drop-down menu now can be customized to display:
both the Average or Current CPU usage levels
only the Average level, with the Current level switched off
only the Current level, with the Average level switched off
Alternatively, the CPU meter can also be switched off entirely.
By default, Live will not display the Current level; it must be enabled from the drop-down menu.
Interface
You can use the left and right arrow keys to switch between radio buttons anywhere in Live. If you are switching between radio buttons on a device that is inside of a Rack with the left and right arrow keys, you can get back to moving between devices in the Rack using the left and right arrow keys by hitting the ESC key.
In Session and Arrangement View, the Monitor radio buttons now have a default state that can be restored. When the In/Out section is expanded, you can press the Delete key to reset the Monitor radio buttons to the default (¡°Off¡± for audio tracks and ¡°Auto¡± for MIDI tracks). This option is also accessible via the Edit menu option ¡°Return to Default.¡±
The Quantize Settings dialog buttons in the MIDI Note Editor now say ¡°Apply¡± and ¡°Close¡± instead of ¡°OK¡± and ¡°Cancel.¡±
Deactivated device title bars are easily readable in all Live Themes, even if the device is selected.
On Mac, the mouse cursor will now display an arrow pointing in a single direction when hovering over split views which can be resized in one direction only.
An error message will be displayed in the status bar if an auto-update cannot be downloaded.
Added a new "MIDI Envelope Auto-Reset" entry to the Options menu:
When enabled, certain MIDI control message types that are not automated for a given clip will automatically reset at the start of a new clip.
Note: for users who intentionally work opposite to this behavior, enabling this change will make corresponding Live Sets behave differently.
In Live 11.0.5, "MIDI Envelope Auto-Reset" is disabled by default.
In Live 11.1, "MIDI Envelope Auto-Reset" is enabled by default for new Sets, and disabled by default in older Sets.
Updated various info texts.
Updated some Help View lessons.
Added support for keyboard shortcuts on French keyboard layouts for macOS versions 10.14 and older. Keyboard shortcuts that have numbers can be accessed without having to press Shift to access the number keys.
Max for Live
Updated the bundled Max build to version 8.2.1.
Link functions have been added to the Max for Live API.
You can access the IDs of newly created notes using the Python API or the Max for Live API.
It is possible to get a dictionary of all the notes in a MIDI clip using the Python API or Max for Live.
It is now possible to call select_notes_by_id on a Clip object in Max for Live, passing a list of note IDs. This will select only those notes that have the provided IDs.
Users can now get and observe the average_process_usage, peak_process_usage, and a track's performance_impact via Max for Live.
When Max fails to load, an error message will be displayed that contains a link to a Knowledge Base article that explains potential causes for the issue and steps to take to resolve it.
Error reporting in the Max Window is more consistent.
Four new theme colors are available in Max for Live.
amxd~: ¡®realtime_params¡¯ attr for realtime report of parameter data from outlets
Dynamic Colors: ability to use a name which references a dynamic color (follows Live or Max color Themes)
live.adsr~ / live.adsrui: new objects
MPE
Added an MPE Settings dialog box to the I/O section of Live¡¯s mixer. You can use the settings to:
configure the MPE zone and range of note channels used by Live when sending MPE to an external MIDI device or plug-in
select the upper or lower zone and number of note channels
select multi-channel mode, which sets an arbitrary range of note channels
The above MPE settings can be used for hardware synths that require a specific MPE configuration, or plug-ins that do not officially support MPE but can be used with MPE controllers due to their multi-timbral support.
Multi-Clip Editing
Time selection interactions, note selection interactions, and new note editing options have been added to multi-clip editing:
Time in the MIDI Note Editor can be selected across loop and clip boundaries.
Note editing (e.g. copy, cut, paste, delete) can be used when working with note selections across clips and loop boundaries.
Notes can be cut or copied from multiple clips and inserted into the same set of clips, as long as the clip selection/foreground clip has not changed, or into a different clip once that new clip has been selected.
Selected loop bars can now be duplicated using the context menu or the CMD + D (Mac) / CTRL + D (Win) keyboard shortcuts.
In Arrangement View, it is possible to draw notes in background clips without first changing the foreground clip. Notes can also be drawn continually across clip boundaries, except in Focus Mode.
When using a pen to draw notes with "Draw Notes with Pitch Lock" enabled, any notes that cross a loop boundary are no longer deleted.
When more than 64 clips or eight tracks are selected in Arrangement View, the MIDI Note Editor is no longer available for multi-clip editing to prevent potential performance issues.
New Devices and Device Improvements
Introduced "Shifter", a new audio effect in Live Standard and Suite. Shifter is a multi-purpose audio effect for pitch shifting, frequency shifting, and ring modulation. The pitch or frequency of incoming audio can be tuned using Coarse or Fine parameters and further adjusted with a Tone filter and Window parameter. Shifter also has Delay, LFO, and Envelope Follower sections for additional modulation. The Shifter device can set pitch or frequency using its own parameters or by incoming MIDI notes.
Introduced the Align Delay device, which is now included in the set of Max for Live devices that come with a Suite license, or a Standard plus Max for Live license. Align Delay is a Max for Live device that delays incoming signals by samples, milliseconds, or meters/feet.
Introduced the Shaper MIDI device, which is now included in the set of Max for Live devices that come with a Suite license, or a Standard plus Max for Live license. Shaper MIDI is a Max for Live MIDI device that uses multi-breakpoint envelopes to generate mappable modulation data.
The Cytomic Filters, which are used in the Wavetable, Echo, Simpler, Sampler, Operator, and Auto Filter devices, have been updated and improved in stability, sound and performance. As of 11.1, the Cytomic filters (particularly the MS2 and SMP options) might deviate in sound compared to previous Live versions, especially when driven hard.
An update to the Softtube libraries may cause subtle sound changes in the Amp and Cabinet audio effects.
In the Sampler, Wavetable, Impulse, Simpler, Channel EQ, Hybrid Reverb, Chorus-Ensemble, Phaser-Flanger, Echo (output knob only), Spectral Resonator (input send only) devices, Gain controls now increment/decrement consistently by 1 dB when pressing the up/down arrow key, or by 0.1 dB when pressing the [Shift] key.
Spectral Time:
The effect order can now be reversed using two radio buttons ¡°Frz > Dly¡± or ¡°Dly > Frz¡± on the right panel of the Spectral Time device above the Dry/Wet knob.
A ¡°Zero Dry Signal Latency¡± option has been added to the context menu in the Spectral Time device. Enabling it reduces the latency of the dry signal to zero instead of syncing it with the output of the effect. This option is useful when playing a live instrument through Spectral Time and monitoring the output.
Spectral Resonator:
In the Spectral Resonator device, the Shift parameter will now increment/decrement by one semitone when pressing the up or down arrow keys, or by one octave when holding the Shift key.
Wavetable:
A context menu option for Hi-Quality mode has been added to the Wavetable device. When Hi-Quality is off, Wavetable modulation is calculated every 32 samples. Low-power versions of the Cytomic filters are also used to further reduce CPU. Using Wavetable with Hi-Quality mode off can save up to 25% CPU compared to having it enabled, which is ideal for working with large sets or maintaining low latencies. Please note that as of 11.1, Hi-Quality mode will be off by default when loading a new instance of Wavetable or any of its Core Library presets. However, any user presets or Live Sets created previously will still load Wavetable in Hi-Quality mode to ensure sound consistency with earlier Live versions. Subtle sound differences may occur when Hi-Quality mode is enabled.
Packs
For the latest Live Pack updates and bugfixes, check out the Packs Release Notes.
Push Device Visualization
On Push 2, the Hybrid Reverb parameter banks Algorithm 1 and Algorithm 2 have been renamed to Algorithm Pg 1 and Algorithm Pg 2. Also some parameters for Hybrid Reverb on Push 2 have been rearranged for easier navigation.
Updated some parameter names for the Chorus-Ensemble device on Push 2.
The Saw Up and Saw Down icons for Sampler¡¯s LFO waveforms on Push 2 now appear as expected.
Session View Improvements
Using the left and right arrow keys to navigate the Session View no longer skips return tracks, if they are visible.
Multi-selecting scenes now behaves the same as multi-selecting clip slots.
Selecting scenes no longer highlights the Master track, instead the scene itself is highlighted.
Navigating from the last clip slot to a scene with the right arrow key will highlight the Master track.
You can click on a scene number or the Master track header to access the Master track and Scene View panel.
Setup
To avoid incompatibilities, you will be asked to save Live Sets created with an older version of Live as a new file in Live 11.1.
In Live¡¯s Preferences, file paths that are unavailable (e.g. if an external drive is not connected) display a ¡°(not available)¡± message. Paths that haven¡¯t been set yet display a ¡°(not set)¡± message.
Bugfixes:
Live Bugfixes
Devices that use beat sync divisions now remain in sync when the device is re-enabled during playback.
The Filter LFO dropdown menu in the Tension device now appears as expected.
Previously, when merging a device chain containing no instrument with another device chain containing an instrument, the instrument would be deleted from the merged chain.
Live no longer moves samples from a temporary project to the final saved project folder.
Fixed a bug that created file path issues with the Live Recordings temporary folder if it was also saved and renamed in Places.
The undo text for changed clip colors has been corrected in the Edit menu.
Previously, if a plugin was grouped into an Instrument or Drum Rack, the MPE settings of the plugin were not retained when the Rack was saved as a preset.
Fixed a crash that occurred if non-supported MPE data (e.g. MIDI CCs other than Pitch, Slide, or Pressure) was sent to a Sampler/Simpler device.
Fixed a crash that occurred when clicking on a parameter in Live and adjusting the same parameter using an encoder on Push at the same time.
Fixed a crash that occurred if all return/delay tracks were deleted and then a track containing a take lane was duplicated and moved. Live would crash if undo was selected twice after duplicating and moving the track.
In the Filter/Mod section of the Delay device, a custom icon for the Ping Pong setting is now displayed on Push 2.
Fixed a crash that occurred when going to ¡°Save Set as Template¡± from the File menu, then typing the name of the set, and finally pressing the [Escape] key twice to cancel the process.
Fixed a bug that caused peak CPU load to be calculated incorrectly if the buffer size selected in Live¡¯s Preferences wasn¡¯t a multiple of 64 samples.
Fixed a crash caused by loading multiple instances of certain VST3 plug-ins when Live¡¯s transport was running.
Fixed an issue in Session View that caused notes to sometimes be triggered twice when recording a MIDI clip with both ¡°Record Quantization¡± and ¡°Chase MIDI Notes¡± enabled.
Fixed an issue caused when using multiple Control Surface scripts that are set to automatically arm MIDI tracks.
When highlighting an area of a take lane using Draw Mode, the clip name appears as expected.
Plug-ins that cannot be loaded appear with a standard device background that includes a more detailed error message.
Loading .alc files from Core Drum Kits into Arrangement View now preserves the Drum Rack chain routings.
In Arrangement View, the dialog box that appears when multi-clip editing is no longer available because more than eight tracks are selected appears as expected.
When several audio clips with different pitch values are selected, you will see the range of values for each clip highlighted in blue on the Pitch dial in Clip View.
Renaming take lanes in linked tracks works as expected.
Folded clips with long fades appear as expected.
Fixed an issue that caused clip fades to reset when resizing adjacent clips.
Fixed a crash caused by some VST3 plug-ins with certain undesignated MIDI CC mapping parameters.
The CTRL + 5 fixed/zoom adaptive grid keyboard shortcut works as expected on Windows.
Fixed two bugs that caused the time selection to not be updated as expected when editing several clips compared to editing a single clip.
E-Piano Wurli.adg preset: Volume Macro is now excluded from randomization.
Womp Bass.adg preset: Typo in original file name is now fixed. If the preset was previously part of Collections it needs to be added again.
Fixed a crash caused by copying and pasting a device from the browser into a Drum Rack¡¯s return chain in the Session Mixer under certain conditions.
Fixed a crash caused by clicking in a certain area of the Sample Editor when editing unwarped audio clips in Clip View.
Fixed a crash that occurred if a user tried to change the scale of a Live Set from Push while having the Focus mode on in multi-clip editing mode without a clip selected.
Fixed an issue that caused some Live Sets to become corrupted even though the sets could be opened normally in earlier Live versions.
Removing the MIDI mapping of the Pitch control in audio clips using the Delete key works as expected.
Fixed a bug that caused the Pitch parameter in audio clips to move too quickly when ¡°Pen Tablet Mode¡± was enabled in Live¡¯s Preferences.
Fixed a crash caused by pressing Tab or Shift-Tab while holding the mouse cursor on a parameter in Clip View.
In Draw Mode, when Pitch Lock is off, users will now get consistent results: a line/curve of notes will follow mouse movement without producing gaps or unexpected layers.
In Draw Mode, when Pitch Lock is on, users can draw back and forth along a key track without removing any notes that are placed underneath (the same as in Live versions prior to 11.0).
When syncing Live to an external MIDI clock, if the MIDI clock signal gets lost, the Ext Sync button will switch off after the dialog in Live appears saying that the signal has been lost.
The grid spacing is now displayed in the MIDI editor as expected after warping and unwarping audio clips.
Fixed an issue when resizing audio clips in Arrangement View using the mouse and Shift key that caused clips to continually be resized even after letting go of the mouse.
Fixed an issue in several Control Surface scripts that resulted in incorrect LED button states when deleting tracks.
Fixed an issue on Apple silicon computers where Drum Racks nested inside of an Instrument Rack could produce CPU overload and audio dropouts even when many of the nested chains were silent.
Fixed a bug that caused the Freezer section of the Spectral Time device to remain active even if the device itself was deactivated.
Fixed an issue that caused auto-updates to fail on certain computers on Windows OS.
Fixed an issue that caused MPE pitch bend breakpoints to be removed if a note transformation, such as Quantization, was applied.
Fixed a crash caused by certain plug-in parameters if they no longer existed in a newer version of the plug-in. Plug-in parameters that are no longer available will be displayed as deactivated.
Fixed a crash caused by pasting a track in Arrangement View immediately after scrolling with a mouse wheel or trackpad.
Fixed a crash that occurred when deleting the last scene in Group Tracks under certain circumstances.
Fixed a crash that occurred when frequently switching the Max for Live Note Delay device on and off in between note on and off messages.
Fixed an issue with the Note Length MIDI effect that caused the incorrect velocity to be generated in release mode if a note was released after recording in a loop.
The Launchpad Mini MK3 control surface script now works as expected when pressing the Scene Launch Buttons after entering and then existing Session Overview.
Fixed an issue that caused the Scale MIDI Effect to cut off played notes if the scale was set to a single note.
AU plug-ins are now informed about silent inputs so that they can release CPU resources and report output silence if possible. This will allow any device in the device chain after the AU plug-in to release CPU resources as well.
Fixed a crash on Windows that occurred if a dialog window opened while a context menu was also visible.
Fixed an issue that caused Push to get stuck on the logo screen.
MIDI notes and waveforms no longer jiggle when dragging a clip back and forth from its left edge.
On Windows, closing a VST3 plug-in window no longer minimizes Live.
In large sets containing thousands of scenes, Live¡¯s UI no longer lags when changing a parameter value with MIDI CC.
Crashes that occurred when dropping a device with no MIDI or audio output onto a device chain are now prevented.
Fixed certain crashes that involved VST3 plug-ins or Max for Live devices on Windows.
Fixed a crash caused by dragging multiple Drum Rack chains into the panel window of the rack that displays how many chains are selected.
Fixed a crash that occurred when freezing or rendering audio in certain scenarios. An error message will now appear saying that the rendering process has been stopped and to contact Support.
A custom location for the User Library or Factory Packs will not reset back to default if Live launches and cannot find the custom path (for example, a disconnected external hard drive).
Fixed several issues with the MackieControl and MackieControl_Classic control surface scripts that caused incorrect button LED feedback.
When using the Mackie Control Surface script, the Mixer button LED will flash on or off depending on whether Follow is on or off in Live.
Max for Live Bugfixes
When the LFO device's modulation waveform exceeds its minimum/maximum, it now draws a horizontal line, as is consistent with the Envelope Follower and Shaper devices. The MPE Control device no longer creates high CPU spikes when receiving MIDI CC 64 (Sustain).
Fixed various bugs that affected these bundled Max for Live devices: Envelope MIDI, LFO, Note Echo, and MIDI Monitor.
Fixed a bug with the Expression Control device.
Fixed a bug that caused the Max for Live device MPE Control to block MIDI Program Change messages.
Key events keep working when a selected Max for Live device becomes invisible.
Selected parameters of a Max for Live device can still be controlled by key events even if the device is no longer visible.
The correct return IDs of newly created notes will be added to new clips when using the Python API or Max for Live API.
Mapped waveforms in the LFO device appear as expected.
Setting the MPE Control device Pitch Curve to an S Curve shape works as expected.
Fixed an issue that could cause CPU spikes when using Channel Aftertouch in the MPE Control device.
Control Surfaces are now represented by their LOM ID as expected when retrieving the list of control_surfaces via live_app in Max for Live.
The waveform displays in the Max for Live devices Envelope Follower and Shaper now appear as expected.
Assigned grooves are no longer lost when using the "duplicate_clip_to_arrangement" Max for Live API function to duplicate a Session clip to Arrangement View.
amxd~: notifies parameter hub when device state changes
jit.gl.model: fixed file loading when embedded in a Max for Live device
jsliveapi: eliminate crash when there's no 'this' for operations
jsliveapi: improved handling of large strings
live.* UI objects: improve negative value handling with some units
live.* ui objects: Outputs the correct value when opened and initialized by pattr
live.banks: error reporting refinements
live.banks: fixed bank renaming in response to '-' argument
live.banks: fixed crash when adding a new bank with index 1 when banks are empty
live.banks: fixed crash with certain 'edit' messages
live.banks: fixed crashing with bad input
live.dial: fixed large mode automation drawing
live.drop: ensure value when restoring
live.scope~: fixed delayed drawing after deletion
Help patchers: fixed crash clicking '?' menu in Live
Device project: fixed hang when changing the "development path type"
Editor Startup: improved Windows startup times
Live Object Model doc: updated with Live 11 additions
Parameters: filters hidden parameters before generating automation for Live
pcontrol: scheduler works in patches opened via load message
Timing: improved locked metro accuracy
Max Console in Max for Live: long text wrapped and shows device name
Object Browser: Max for Live UI objects shown in correct category
Object Palette: icons added for all live.* UI objects
Parameters Window / Inspector: auto-quote Info Title / Info
Parameters: only dirty if it exists in a Max for Live device
Performance: CPU usage improvements after starting Editor
jit.gl.lua: fixed outlet functionality (fixes Inspired by Nature Max for Live devices)
live.scope~ / live.adsrui: updated icons
umenu: improved popup positioning with multiple displays at mixed resolution/zoom
Windows: increased main thread stack size to match OSX (8 MB)
11.0.12 Release Notes
11.0.11 Release Notes
Bugfixes:
11.0.10 Release Notes
Arrangement View
It is now possible to solo tracks with the "S" key and arm tracks with the "C" key when take lane headers or automation lane headers are selected. Before, this was only possible when track headers were selected.
Pressing "Tab"/"Shift"+"Tab" while renaming an Arrangement clip now selects the next/previous clip on the same track or take lane.
When reaching the end when navigating with the "Tab"/"Shift"+"Tab" or Arrow Up/Down keys while renaming tracks or clips in the Session or Arrangement View, the navigation now cycles to the beginning or end of the tracks or clips, similar to using "Tab"/"Shift"+"Tab" when renaming scenes.
It is now possible to fold/unfold a track's additional automation lanes with the left/right arrow keys when that track's main automation lane is selected.
Clip View
When transposing an unwarped audio clip:
The time ruler below the waveform will change to show the accurate amount of seconds in the waveform.
The play position is preserved, causing smooth playback of the waveform and respecting scheduled Follow Actions.
Comping
When choosing a take lane for recording, Live now uses the first take lane that provides enough space. Before, Live used the take lane following the last take lane that did not provide enough space.
Previously, unnecessary splits might be created on an Arrangement track's main lane, when dragging the split line of adjacent highlights on a take lane. Now the behavior when resizing adjacent take lane highlights is more consistent.
The vertical size of take lanes on linked tracks is now synced with a take lane that is being resized by dragging. The position of the dragged lane is sustained to keep the visible resized dragged lane visible and avoid jumping.
Control Surfaces
Added the following improvement to the functionality of User Remote Scripts:
Device Control:
Up to 16 encoders can be used for controlling Device Parameters.
The Device Activator button can be controlled.
Mixer Control:
An unlimited number of Tracks can be controlled.
Track Mute, Solo and Selection can be controlled.
The Crossfader and Cue/Preview Volume can be controlled.
Transport Control:
Session Record, Arrangement Overdub, Metronome, Punch-In, Punch-Out, Nudge
Down, Nudge Up and Tap Tempo can be controlled.
Follow Actions
When transposing an unwarped audio clip, the position of the Follow Action marker will change to keep in sync with the playhead and the actual beat-time of the Follow Action.
Interface
On Windows, if a UI element has the focus, its context menu can now be opened via the Menu key or "Shift"+"F10".
On Windows, context menus shown when pressing "Shift"+"F10" more accurately represent what would be shown when right-clicking using the mouse.
When Sets are saved with the File menu's "Save Live Set as Template..." or "Save Live Set as Default Set..." command, they are automatically self-contained in the same way as Sets that use the File Manager¡¯s "Collect and Save" function.
The splitter between Live's main window and the Help View can now be grabbed and adjusted at its full height.
Note names in Drum Rack pads are now displayed until no character fits at all. Standard note names are now displayed without the octave number if the full name does not fit.
Live now has improved performance in certain scenarios.
MIDI Editing
Added the following changes to how velocity/probability values are displayed:
A MIDI note's velocity/probability values are now displayed in the respective Velocity/Chance Editor¡¯s lane header when hovering over its velocity/probability markers.
In Draw Mode, a note's velocity/probability values are displayed when hovering over the area in which the drawing action is available for that note. If any notes are selected, only those note's values can be displayed in the ruler, and hovering respects the quantization grid.
When drawing a velocity/probability ramp, the value range is displayed in the respective Velocity/Chance Editor¡¯s lane header. If any notes are selected, only those note's values can be displayed in the ruler, however hovering does not respect the quantization grid.
When adding a new note to a MIDI clip or reactivating a previously deactivated note, if the clip is playing and the playhead is within the new or deactivated note, the note will be played immediately.
MPE Editing
When the Note Expression tab is open, a "Clear All Envelopes" entry in the context menu of the MIDI Note Editor and per-note expression lanes clears all expression envelopes of one or multiple selected notes.
Stretching a MIDI note using the MIDI stretch markers in the MIDI Editor or the ¡Â2 and x2 buttons in the Notes tab will now cause any per-note expression belonging to that note to be stretched as well.
When sending notes to a plug-in device, external device, or Max for Live device that has MPE Mode enabled, reoccurring notes with the same note number will now reuse the same channel. This can result in more consistent behavior of multitimbral instruments.
MIDI track meters now indicate MPE per-note controller changes. The lowest dot in a meter lights up in a blue color if per-note controller changes pass that meter.
Plug-in devices that have MIDI outs and that have MPE enabled can now output MPE.
Spectral Time:
The Freeze Trigger LED in the Spectral Time device is now visible and flashes when Retrigger mode has Sync enabled.
Wavetable:
When the transport is stopped, any hanging notes in the Wavetable device will now be stopped, as in other Live instruments.
Session View
Making a selection (or multi-selection) using keyboard navigation in the Session View's scene area now works as expected.
It is now possible to navigate to and rename the next/previous track using the "Tab"/"Shift"+"Tab" keys while renaming multiple selected tracks in the Session View. Previously, this only worked in the Arrangement View.
When resizing the Session View, the clip slot selection will stay in view as much as possible. When the selection is off-screen, resizing the Session View does not scroll to show it.
Pressing "Shift"+"Tab" now selects the previous clip while renaming a Session clip.
When renaming a Session clip, the "Tab"/"Shift"+"Tab" keys now skips empty clips slots.
Bugfixes
Arrangement View
Previously, reactivating a take lane selection when Draw Mode was enabled would create a flickering effect.
Previously, the automation control chooser is empty instead of showing "None" when loading a new Set and "Show Automated Parameters Only" is chosen. Also, clicking on the automation control chooser would not select the main automation lane header when "Show Automated Parameters Only" is chosen. These bugs have been fixed.
Previously, trying to resize multiple selected tracks via the resize handle of the last automation lane would resize the main automation lane instead.
Previously, certain elements (such as insert markers, the loop brace and fade handles) were drawn on top of the Single Track Back to Arrangement button.
Previously, the triangle icon in the Single Track Back to Arrangement button was cropped when the track was almost scrolled almost out of the visible Arrangement View. Now the triangle icon is only shown when it can be fully displayed.
Recording auto-quantization now applies to take lane clips as well as main lane clips.
Previously, the Arrangement View would abruptly scroll upwards after renaming a clip in a take lane at the bottom of the view. Instead, the clip's take lane is now scrolled into view. Similarly, the clip's main lane is now scrolled into view when renaming a main lane clip, whereas before, the entire track (including take lanes and automation lanes) was scrolled into view.
Clip View
In the Sample tab, typing arbitrary values into the Pitch control's Transposition/Cents field now works as expected. Dragging the Transposition/Cents slider beyond the minimum/maximum pitch also now works as expected.
Control Surfaces
Mapping the Macro Variations selector to relative MIDI controllers now works as expected. A controller that sends high-resolution pitch bend can now be mapped to the scene selector and the snapshot selector.
The LEDs surrounding the encoders on the Novation Remote SL MkII once again provide feedback about the value of the controlled parameter.
Devices
Some Racks that only contain licensed Max for Live devices and were previously locked in certain editions of Live (such as the DS Drum Rack in Live Standard) are no longer locked.
Plug-in window titles now update when changing the name of the containing track. AU plug-in devices are now displayed as disabled if plug-in creation fails.
In order to prevent an issue with filter cutoff being reset on every note start in the TAL J-8 plug-in, the VST3 version of the plug-in is no longer loaded in MPE Mode by default. The VST2 version of the plug-in will still load in MPE Mode by default.
Arpeggiator:
Fixed a bug that could cause a crash when repeatedly adding and removing notes from a held chord when using the Arpeggiator device with the Hold parameter active.
Collision:
Fixed a regression that resulted in missing parameters in the Collision device.
Hybrid Reverb:
Previously, Live would crash when loading a one-sample length file into the Hybrid Reverb device and adjusting the Size parameter.
Sampler:
Previously, cropping a sample in the Sampler device would chop off the portion of the sample between the Release Loop Start and the Loop Start, if the Release Loop Mode was set to "Loop Back and Forth" and the Release Loop Start was before the Sample Start point.
Tension:
Interface Improvements
Fixed an incorrect error message that appeared when trying to insert a non-audio device into an Audio Effect Rack.
Corrected the Edit menu entry text for undoing a clip color change.
Fixed a crash that could occur when undoing in a Set that had previously been restored after another crash.
Previously, Live's crash recovery would silently fail if the undo history contained an empty band file (e.g. after a power outage).
Under certain circumstances on macOS, audio/MIDI meters, the global transport time and other parameters would stop updating while editing parts of a Live Set with the mouse or a trackpad.
Previously, when clicking on a half-hidden track header to select it, Live might sometimes copy or move the track.
Fixed a crash that occurred when freezing a track in a Live Set that contained an external MIDI instrument that was routing MIDI to a device in the Master track.
Previously, renaming did not work as expected when selecting a track header or take lane header and unselecting the cursor item using "CMD"+click (Mac) / "CTRL"+click (Win).
Fixed crashes and error messages pertaining to corrupt documents that occurred when loading some Live Sets.
Fixed crashes that occurred after deleting a device while a take lane clip has an envelope for that device.
Fixed a crash that occurred when renaming a take lane inside of a linked track and then pressing Tab.
Fixed document corruption and subsequent possible crashes or other issues when restoring a Set after a crash under certain circumstances.
Fixed the alignment of shortcut entries in Live¡¯s context menus on macOS.
Fixed a bug where Live would not accept tempo changes from Link peers in some cases.
Max for Live
Zooming Arrangement tracks via the Max for Live Application.View.zoom_view API function no longer breaks when multiple automation or take lanes are visible.
MIDI Editing
Pitch Bend, Sustain, Expression, Mod Wheel, and other MIDI controllers that one would expect to reset to a default value will now do so at the beginning of clips that do not specify them. (Note: for users who intentionally use the previous behavior, this change will make their Live Sets behave differently. Therefore, the behavior is disabled by default. The behavior can be enabled by checking the "MIDI Envelope Auto-Reset" entry in the Options menu.)
Improved Live's performance when a very large amount of notes are visible in the Velocity or Chance Editor.
Previously, when changing note velocities or probabilities with the Arrow Up/Down keys, Live would not show the changed value when the mouse was hovering over the respective editor.
Previously, the MIDI Editor pitch grid might jump by one pixel when folded on tracks with a Drum Rack while Highlight Scales was disabled.
Fixed a bug that caused MIDI notes in a selected area to get deleted even if the notes themselves were not selected when pressing Delete.
MPE Editing
Fixed a bug where selecting or deselecting MIDI notes showed unexpected behavior or was not possible when the Note Expression tab was open and the MIDI Note Editor had Fold enabled.
Fixed a bug where the per-note breakpoint editor would not be focused when clicking on an expression curve in the Pressure or Slide lanes, when the Note Expression tab was visible.
Fixed a bug that could cause a crash when using MPE data with MIDI Effect Racks.
When the Note Expression tab is open and no note is selected, double-clicking on the Note Ruler now correctly zooms to all notes including their pitch-bend curves.
Fixed an issue where a note could have per-note events behind the note end when recording a transposed MIDI clip into the Arrangement.
In the unlikely event that an extremely high amount of MPE control change messages come in, Live will no longer crash, and all notes will be stopped.
Previously, when the Note Expression tab was open, moving the mouse from an unselected expression curve to a selected expression curve could cause the highlight to become stuck.
The Insert Time and Delete Time commands are no longer available when editing per-note expression breakpoints. Fixed a bug that could cause per-note expression to play incorrectly after a note-editing action resulted in an existing note becoming shortened.
Fixed an issue where undoing a per-note breakpoint editor change while the breakpoint editor was not open would not redraw the expression curves.
The Duplicate Time command is no longer available when editing per-note expression breakpoints. Fixed a bug where the Duplicate command would truncate the original note when duplicating the selected note while working in the per-note expression breakpoint editor.
Plug-ins
Fixed a crash that occurred when opening a Live Set that contained a plug-in with sidechain automation/modulation that could not be loaded.
Push
On Push 2, the Spectral Resonator device's main bank parameter now correctly switches to Transpose when the sidechain mode is set to MIDI.
Session View
Fixed a bug where mappings in MIDI/Key Map Mode were hidden by the scene number.
Navigating with the Tab key once again works as expected when renaming scenes.
Fixed a bug where Follow Actions were not scheduled as expected, under certain circumstances.
Fixed a crash that occurred when pressing the [Space] or [Tab] key after clicking on Track Status Display in Session View if a clip in Arrangement View was being played.
Setup
Previously, exporting audio might start single-threaded rendering before switching to multi-threaded rendering after a while. This could impact render performance significantly for Live Sets that benefit from multi-threaded rendering.
Improved shared Library folder setup when installing Live in multi-user environments.
The Library.cfg file in a shared Preferences folder now gets copied as expected when installing Live in a multi-user environment.
Fixed a crash that occurred in certain scenarios if two instances of Live were running at the same time.
11.0.6 Release Notes
Bugfixes:
Fixed an issue where the Session frame of the ATOM control surface script was visible even when the hardware was not connected.
11.0.5 Release Notes
Arrangement View
Using "CMD"-click (Mac) / "CTRL"-click (Win) no longer deselects track headers that contain a hidden lane selection.
Take lane headers with a standby selection are now shown in the respective standby selection color when more than one track, take lane, and/or automation lane is selected.
It is now possible to rename multiple selected tracks simultaneously.
Clip View
The Sample tab's Clip Gain control has been changed back to a vertical slider, and it has been repositioned above the Transpose controls.
The Sample tab's Reverse button now shows an icon instead of text.
The Sample tab's Reverse and Edit buttons are now positioned next to each other.
Added a Pitch dial to the Sample tab, which enables shifting an audio clip's pitch in semitones. The Transpose controls now appear as adjacent slider controls, positioned beneath the Pitch control.
When multiple audio clips with different Clip Gain values are selected, the value range is shown with split triangle handles on the Clip Gain slider.
Added some visual refinements to the Clip View tabs.
Improved the names of MIDI controllers that appear in the Control chooser when the Clip View's Envelopes tab is visible and the "MIDI Ctrl" is selected in the Device chooser.
Follow Actions
The Follow Action Chance slider now displays a split triangle instead of just a black bar when it is showing multiple different values.
Interface
Updated various Help View lessons.
Updated various Help View lesson translations in German, Spanish, French, Italian, Japanese and Chinese languages.
Updated some Japanese and Chinese info text translations.
The audio engine can now be turned on or off via a new "Audio Engine On" entry in the Options menu, or using the "CMD"+"ALT"+"Shift"+"E" (Mac) / "CTRL"+"ALT"+"Shift"+"E" (Win) keyboard shortcut.
The Overload Indicator is disabled by default for new Live 11 installations.
Live's performance is improved when deselecting many clips at once.
Max for Live
Updated the bundled Max build to version 8.1.11. For the changelog, visit: http://cycling74.s3.amazonaws.com/support/version_8_1_11.html
The following new properties and functions are available in the Clip API:
add_warp_marker
move_warp_marker
delete_warp_marker
sample_rate
sample_length
The Max for Live API now supports large dicts.
MIDI Editing
It is now possible to resize the velocity, probability, and per-note expression lanes in the MIDI Editor using the mousewheel/pinch gesture while holding "ALT".
The background color of lane headers is now consistent with the Notes tab.
Clicking on a lane with a standby selection now selects that lane instead of collapsing the time selection.
MPE Editing
The "Pitch Bend Range Settings..." context menu entry now appears when right-clicking in the area where per-note pitch-bend is editable.
When the Expression tab is open, making a time selection in the Note Editor or the Slide/Pressure expression lane while editing per-note expression now only shows the focused lane with a selection highlight, while all other lanes are shown with a standby selection highlight.
When the Expression tab is open, using the "Zoom to Clip Selection" command (or "Z" key shortcut) now adjusts the zoom level according to pitch bend values contained in the time selection.
It is now possible to clear all per-note Pitch, Slide and Pressure expression envelopes of a note at once by using the "Clear All Envelopes" entry in the context menu of the per-note expression breakpoint editor.
Multi-Clip Editing
When clips are selected/unselected in the Session View, the highlighted track and scene now point to the foreground clip, if any exists.
Changing the foreground clip from the Clip View updates the highlighting of the track (in both the Session View and Arrangement View) and the scene corresponding to the new foreground clip.
Clicking on a clip's multi-clip loop bar in the Clip View updates the highlighted track, even if this clip is already the foreground clip.
The enabled/disabled state of a plug-in device's MPE Mode is now saved with that device's default configuration.
Plug-in devices now look similar to built-in Ableton devices when disabled.
Chorus-Ensemble:
The Chorus-Ensemble device now uses less CPU when certain settings are applied.
Phaser-Flanger:
In the Phaser-Flanger device, when the LFO Stereo Mode is set to Spin and the Spin value is changed, a second LFO line is now visible and its frequency changes accordingly.
Spectral Resonator:
The Spectral Resonator device now uses about 15% less CPU.
The Spectral Resonator device now uses about 20% less CPU when very few partials are audible.
The spectrogram should now display about 30% of its former CPU load. Note: this is only visible in the system's CPU monitor, not in Live's audio processing meter.
When low polyphony and unison voices are set, less CPU usage should be shown.
Spectral Time:
The background of the Stereo slider now displays a blue color when its value is above 0%.
"Freeze On/Off" is now called "Frozen On/Off" in Automation Mode and on Push.
"Delay DryWet" is now called "Delay Mix" in Automation Mode, and "Mix" in the device UI and on Push.
In the Spectral Time device, the spectrogram should now display about 30% of its former CPU load. Note: this is only visible in the system's CPU monitor, not in Live's audio processing meter.
The Spectral Time device now runs at about 60% of its previous CPU load.
Wavetable:
Added support for Drum Rack choke groups to the Wavetable device.
Push
When editing multiple MIDI clips at once, a connected Push device now follows all highlight changes of tracks/scenes, and the focus on the corresponding track.
Updated the notification style for scenes, and updated the scene name visualization to include the absolute position, tempo and time signature on Push.
Adjusting multiple encoders while recording automation now creates less undo steps on Push 1 and 2.
Session View
When a Session track slot is highlighted but not selected, using the Arrow Up/Down keys, Home/End, or PageUp/PageDown keys now moves the highlight to the adjacent track slot in the given direction.
It is now possible to rename multiple selected scenes simultaneously.
In the Session View's Track Status display, the remaining play time of an unlooped clip now always displays the seconds with two digits (e.g., "10:07" instead of "10:7").
Control Surfaces
Added control surface support for the Roland Fantom.
Added control surface support for the M-Audio Hammer 88 Pro, Oxygen Pro Mini and Oxygen MKV Series.
The functionality of the Oxygen Pro control surface script has been drastically changed. Specifically:
The Rewind and Fastforward buttons will now rewind and fastforward the Arrangement position.
Turning the Encoder will now scroll the Session frame up and down.
Holding the Encoder down and turning it will scroll the selected Scene up and down.
The Knobs can now control multiple features (Device parameters, Track Panning, Track Sends and, in the case of the 25 key, Track Volume) that can be selected
by holding down Shift and pressing the Pads used for DAW KNOB CONTROL.  Additionally, it is possible to toggle between controlling Send A and Send B
by holding down Shift and pressing the SENDS Pad.
Live's Takeover feature is now enforced for the Knobs and Faders when switching between DAW and Preset Modes.
The Pads now provide LED feedback in respect to Clip/Clip Slot states in Live.
The Buttons beneath the Faders can now control multiple features (Track Arming, Track Muting, Track Soloing and Track Selection) that can be toggled
between via the Mode button.
Fixed an issue where the Session frame was visible even when the hardware was not connected.
Bugfixes
Arrangement View
Fixed an issue where Live hangs when zooming in Arrangement View in some cases.
Previously, reordering automation lanes via dragging and dropping or using the "CMD" and Arrow Up/Down (Mac) / "CTRL" and Arrow Up/Down (Win) keys would not mark the document as modified.
Fixed the width of the divider line between Arrangement lanes and track/lane headers.
Previously, after selecting content by clicking on the Arrangement loop brace or pressing "CMD"+"A" (Mac) / "CTRL"+"A" (Win), content of tracks nested in a folded Group Track would not be selected when unfolding the containing Group Track.
Previously, track lanes and headers could not be deselected via "CMD"+click (Mac) / "CTRL"+click (Win) when their tracks contained hidden and selected automation lanes, take lanes, and/or Group Tracks.
Fixed a crash that could occur when restoring the Arrangement View's zoom state using the "Z" keyboard shortcut after deleting a take lane.
Fixed a crash that could occur when clicking in a track's main lane after track content had been selected during recording, under certain circumstances.
Previously, mixer controls in linked tracks would still be linked when selecting a take lane, after multiple track headers had previously been selected.
Arrangement clip headers no longer have an uneven appearance.
Previously, an Arrangement clip header would not be displayed as having a standby selection when the focus was moved away.
Previously, it was not possible to unlink all tracks when some tracks were nested inside a Group Track.
Fixed a crash that occurred when inserting a take lane.
Fixed a crash that could occur when trying to move a selected main automation lane by pressing the "CMD" and Arrow Up/Down (Mac) / "CTRL" and Arrow Up/Down (Win) keys.
Control Surfaces
User Remote Scripts work as expected on Windows again.
Devices
The EQ Eight device will now scale the displayed spectrum the same way as the Channel EQ and Hybrid Reverb devices.
Previously, the Operator device could crash or calculate inaccurate frequencies when its Fixed Mode and Spread parameters were enabled.
In the Spectral Resonator and Spectral Time devices, the limiter's LED now correctly lights up when the limiter is active.
Switching between oscillator effects in the Wavetable device now changes labels within each matrix as expected.
In the Sampler, Simpler, and Wavetable devices, the MPE label text now updates according to the device's selected/deselected state.
Previously in the Spectral Resonator and Spectral Time devices, gaps would sometimes appear in the Spectrogram at high frequencies.
A Max for Live device's background color now updates correctly after moving that device between tracks.
Fixed two bugs in the MPE Control device:
The Pressure curve would not follow Live's themes when the device was instantiated while using the Dark theme.
Global PB would be interpreted as Note PB under certain circumstances.
The Surge Synth Team's "Surge" VST/AU plug-in device now has its internal MPE Mode activated by default when started in Live. Deactivating the device's MPE Mode in Live will also cause Surge to deactivate MPE Mode internally.
Mouse-clicks on a return track no longer "fall through" to audio/MIDI tracks or Group Tr
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
