Venn Audio is proud to present Viper - Professional Streamers Plugin
2022-2-3 11:35| ·¢²¼Õß: volunter| ²é¿´: 795| ÆÀÂÛ: 0
ÕªÒª: Venn Audio is proud to present Viper - Professional Streamers PluginViper is a 'streamers' plugin for recordists working to picture. If you record Foley, ADR or musical score, this is for you. It is t ...
Viper is a 'streamers' plugin for recordists working to picture. If you record Foley, ADR or musical score, this is for you. It is triggered by midi notes in your DAW and requires no other application - it sits in your template, ready to go when you start your session.
Simple to use, yet customizable and flexible ¨C if you are still cuing actors with beeps or using out-of-date software to overlay wipes, give Viper a free try.
Buy for just $45 or try for free!
Order here: https://www.vennaudio.com/product/viper/
Available for Windows as VST, VST3 or AAX, and for MacOS 10.9+ as Audio Unit, VST, VST3 or AAX.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
