Signum Audio. SKYE Dynamics - Bring Your Sound To Life
2022-1-22 08:47| ·¢²¼Õß: 6627540| ²é¿´: 1057| ÆÀÂÛ: 0
ÕªÒª: Signum Audio. SKYE Dynamics - Bring Your Sound To Life | Multi-stage Dynamic Processor PluginSKYE DYNAMICS IS A MULTI-STAGE, THREE-IN-ONE DYNAMICS PROCESSOR FOR MUSIC PRODUCTION. IT COMPRISES OF AN EX ...
SKYE DYNAMICS IS A MULTI-STAGE, THREE-IN-ONE DYNAMICS PROCESSOR FOR MUSIC PRODUCTION. IT COMPRISES OF AN EXPANDER, COMPRESSOR AND LIMITER DELIVERING ULTRA-TRANSPARENT PROCESSING.
CLEAN AND TRANSPARENT
With algorithms specifically designed for transparency, SKYE Dynamics delivers exceptionally low levels of distortion and saturation. SKYE Dynamics also features an advanced adaptive auto release and a selection of 5 envelope presets for each processor, making it a standout tool for mixing and mastering music.
 Skye Dynamics Compressor Expander Limiter Processor
GET CREATIVE
SKYE Dynamics includes a comprehensive array of features for creative uses. Each effect in the chain can be individually bypassed, gain staging can be done at any point in the chain, and each effect has its individual side chain. All of this can be automated. A channel linking system allows further tailoring of the input and output of the plugin. SKYE Dynamics opens up completely new creative possibilities.
STREAMLINED AND INTUITIVE
The plugin boasts a unique user interface that lets the user configure the whole effect chain intuitively from a single view. Metering and configuration automatically update and switch to the selected processor.
SKYE Dynamics focuses on workflow optimization and is completely interactive. The dynamic range of the metering and the graphical effects configuration can be zoomed and out to cater for different material. The plugin window can also be freely resized and offers a streamlined compact view.
Skye Dynamics Processor Compact View
SKYE Dynamics Processor Mac Windows VST VST3 AU AAX
READY FOR SPATIAL MIXING
The Surround version of SKYE Dynamics is compatible with setups up to 7.1.4. With full surround support for the channel linking feature, you can also get creative with spatial mixing.
COMPATIBILITY
Like all of our plugins, we aim to be compatible with as many set ups as possible. SKYE Dynamics is compatible with Mac OS or Windows, and VST / VST3, AU and AAX formats making it work with most software configurations.
STUDENTS GET 50% OFF
We are committed to supporting upcoming producers which is why we're offering students and educators 50% off any of our tools.
To redeem your discount, get in touch with us at education@signumaudio.com including proof of your student status.
AN EXTRA 10% OFF FOR CROSS-GRADERS
If you already bought a plugin direct from us, you can get a 10% cross-grade discount off SKYE Dynamics. Use the code SKYEBUTEX10 at checkout. You must be logged into your account for this to work.
POSSIBLE APPLICATIONS
Mixing & Mastering
Post-production
Music production
Game audio production
Drum bussing
Vocal processing
SFX processing
FEATURES OVERVIEW
A plugin for multi-staged dynamics processing
Three dynamics effects - Exander, Compressor, Limiter
Ultra transparent processing
Linear, Natural, Transparent, Smooth and Pumping envelopes
Advanced adaptive auto-release
Individual Side Chains to each processor
Individual bypass for each processor
Channel Linking (up to 7.1.4 configuration in the Surround version)
Gain Stage at any point
Intuitive node based UI to configure effects chain
Dynamic range for metering and effects configuration can be freely scaled
Full and compact view for optimising screen space
Fully resizable/scalable plugin window
Multichannel input/output metering for effects chain and individual effects (Surround version)
Compatible with Mac OS or Windows
VST / VST3 / AU / AAX formats
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
