Steinberg Dorico major update
2022-1-22 08:12| ·¢²¼Õß: 6627540| ²é¿´: 1081| ÆÀÂÛ: 0
ÕªÒª: Steinberg Dorico 4 major updateSmart MIDI import and powerful new workflow features addedSteinberg have announced the immediate availability of major new updates to its Dorico family of music notation ...
Steinberg have announced the immediate availability of major new updates to its Dorico family of music notation and composition software. Every member of the family, from the free Dorico for iPad and Dorico SE, through the mid-range Dorico Elements, to the flagship Dorico Pro, is refreshed with powerful new workflows.
Highlights
Easy note input using on-screen instruments, MIDI keyboard, or external keyboard
Intelligently adjusts notation as you write
Any number of movements or pieces in a single project
Automatic layout of instrumental parts
Expressive playback using included sounds and effects
Supports VST 3 (Mac, Windows) and Audio Unit (iPad) virtual instruments and effects processors
Revamped Key Editor, with piano roll, velocity and continuous controller editors
Sophisticated chord symbols, unpitched percussion and drum set notation
Unbarred music, tuplets across barlines, etc. all handled correctly ¡ª no workarounds
Projects are fully compatible between Mac, Windows, and iPad
Transfer to and from other apps via MusicXML, MIDI, PDF, etc.
Smart MIDI import
Bringing MIDI data into music notation software from a large orchestral template in a DAW can take hours, meticulously copying and pasting music from one staff to another, deciphering track names to work out what instrument and playing technique they might represent. Dorico 4 thankfully introduces a powerful new MIDI import workflow that intelligently interprets incoming tracks, and remembers the user¡¯s choices for future imports.
Polyphonic MIDI transcription
Whether using the new smart MIDI import workflow or recording music in real time from a MIDI keyboard, Dorico 4 now automatically separates the music played into separate voices, producing a much cleaner transcription than ever before. With melodies, bass lines and inner textures automatically captured.
Key Editor in Write mode
With the introduction of a dedicated Key Editor in the lower zone in Write mode, it¡¯s now easier than ever to shape the MIDI performance of music notation. The view is automatically kept in sync, so users will never get lost. Editing continuous controllers, dynamics and velocities in line with the music notation.
On-screen keyboard, fretboard and drum pads
The lower zone in Write mode houses the Properties panel, the new Key Editor, and the Mixer, plus three new on-screen instruments to make note input quicker than ever ¡ª and all of them are touch-enabled for Windows devices with touch screens, like the Microsoft Surface. You can click or tap notes into the score from the piano, input guitar tab directly by touching the string and fret on the fretboard or see all of the percussion instruments at a glance with the drum pads.
Revamped Play mode and Mixer
Play mode has been restructured to make it more streamlined. With the Key Editor now accessible in the lower zone, the track overview has been simplified, with the introduction of a new track inspector on the left providing quick access to routing, channel settings, and more. The Mixer in Dorico 4 has also been rebuilt from the ground up.
Native Apple Silicon support
Dorico 4 now runs natively on Apple¡¯s new M1-powered Macs and some editing operations are now twice as fast on Apple Silicon than on in Intel-powered Macs.
Flexible new license management
Dorico 4 uses Steinberg¡¯s new identity-based license management system and allows you to run it on three computers with a single-user license by signing in on each machine ¡ª no need for the USB eLicenser.
Availability and pricing
Dorico is available from resellers and through the Steinberg Online Shop. The suggested retail price for Dorico Pro 4 is
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
