GuDa Audio releases "Eko" - Echo plugin
2022-1-10 11:15| ·¢²¼Õß: audioess| ²é¿´: 593| ÆÀÂÛ: 0
ÕªÒª: GuDa Audio releases "Eko" - Echo pluginGuDa audioGuDa Audio has released Eko (Swedish for echo), an echo plugin with chorus, tape flutter, filtering, and saturation for a non static evolving echo.Dela ...
GuDa audio
Delay time can be set freely or synced to host with all common timing including triplet and dotted timings.
Details:
Stereo, cross stereo and ping pong mode.
Stereo width to control left right timing offset and width of ping pong from center to hard panned sides.
Tape flutter, emulates an unstable tape echo for a moving echo.
Simple color knob that EQs the lows or highs for that classic filtered echo.
Saturation is mild saturation to bring some grit to the echo.
Chorus to bring width and no static-ness and at high settings a reverb like echo.
Ducking, a smart side-chained compressor that automatically ducks echo sound and lets through original signal.
The colors in the GUI can be changed from a range of color sets.
Zoom in our out from 25% to 200% GUI size.
Price: 19 $/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
