Obsession
2022-1-10 10:15| ·¢²¼Õß: landom| ²é¿´: 667| ÆÀÂÛ: 0
ÕªÒª: Obsession brings the power of a great polyphonic vintage synthesizer to your fingertips. It combines the astute modeling of voltage-controlled oscillators (VCOs), voltage-controlled filter (VCF) and v ...
Obsession brings the power of a great polyphonic vintage synthesizer to your fingertips. It combines the astute modeling of voltage-controlled oscillators (VCOs), voltage-controlled filter (VCF) and voltage-controlled amplifier (VCA) with a comprehensive individual voice control that has never been done before in this detail.
Key features:
Two part engine with 8 or 16 voice boards.
Single/Dual/Split modes.
High-quality effect block with Delay, Reverb and Chorus.
Precise control of many sound parameters per voice board.
Stepped LFO with freehand drawing for rhythmic sequences.
Scalable GUI, Retina-ready.
Support for Multidimensional Polyphonic Expression (MPE).
420 patches by leading sound designers.
NKS Approved
Obsession is NKS-ready. Its factory library is automatically integrated into Maschine, Komplete Kontrol etc., with all presets properly tagged and a custom parameter map.
Formats
Obsession is available in VST, Audio Unit and AAX formats (all 64-bit), for Windows and OS X.
Factory Patch Demonstration:
{See video at top of page}
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
