Physical Audio releases Derailer v3.1 with Intro Offer
2021-12-17 10:50| ·¢²¼Õß: daniel| ²é¿´: 743| ÆÀÂÛ: 0
ÕªÒª: Physical Audio releases Derailer v3.1 with Intro OfferPhysical AudioPhysical Audio has announced the release of a major new version of their physical modelling instrument Derailer.This new version of ...
Physical Audio
This new version of Derailer has been rewritten from scratch incorporating an extended model using a driver and resonator setup. Built entirely from physical models of strings, bars and spring connections, this new version delivers a wide range of sounds from cutting leads to huge soundscapes.
Derailer uses physical models of 3 basic elements; strings which can be plucked or bowed, metal bars which can be pitched or act as resonators, and nonlinear springs which can be used to connect resonators together to form a network. The physical parameters of the driver and resonator provide a flexible system which can be configured to create your own unique instruments.
Features:
5 excitations options: plucked strings, bowed strings, pitched bars, sawtooth and multi-striker.
Effects units including low-pass resonant filter, delay and overdrive.
Resonator network using up to 5 metal bars and 10 nonlinear springs.
The plugin is available in standard formats for macOS and Windows, and can be tested in demo mode.
Into Price:$125/ 90 through September 2021 (Reg. $179/130).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
