LibreArp
2021-12-17 10:32| ·¢²¼Õß: daniel| ²é¿´: 732| ÆÀÂÛ: 0
ÕªÒª: LibreArpLibreArp is a pattern-based arpeggio generator plugin.LibreArpLibreArp is a free open-source project developed by the LibreArp contributors. It¡¯s a very useful MIDI effect that generates patt ...
LibreArp
LibreArpLibreArp is a free open-source project developed by the LibreArp contributors. It¡¯s a very useful MIDI effect that generates pattern-based arpeggios. You can play chords via the MIDI input on your keyboard or controller, and the plug-in will send the resulting arpeggio to the synth of your choice. For editing patterns, LibreArp boasts a neat piano-roll interface, which is easy to use and very visual. You can save user patterns and export and import arpeggios. Very cool!
LibreArp is available for macOS, Linux and Windows in VST3 and LV2 formats (64 bit).
Gitlab»ñÈ¡£ºhttps://librearp.gitlab.io/
https://plugins4free.com/plugin/3543/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
