| HoRNet releases SongKey MK4, key chord and tempo detection tool HoRNet SongKey MK4 is the fourth version of our key recognition tool, but it doesn¡¯t do simple key recognition, it¡¯s also capable of detecting the chord being played and the song tempo. We thought it was a good idea to also add MIDI input (to be able to detect chords and key of midi tracks) and MIDI output for the recognised chords so you can record them and edit the track for your own needs, also SongKey MK4 provides new standalone version that is able to generate midi clock to keep all your other MIDI gear in sync with a live audio input. Of course this new SongKey provides better accuracy in every aspect: key recognition is faster and more precise, chords are detected more precisely and tempo is more accurate. Features: Artificial Intelligence driven key identification that follow key changes Realtime audio and MIDI chord detection Confidence display for each found key Key and Chord chromagram that shows each note level Key and Chord piano roll view to see which notes are active Sample mode for short sounds analysis Realtime tempo detection MIDI output of detected chords Stand alone App for both Mac and Windows MIDI clock output (in the stand alone App) Sharp and Flat notation Resizable vector GUI Hardware accelerated GUI Apple M1 support macOS (10.11 and later) and Windows (7 and later, OpenGL 2.1 required) support. 64-bit only plugins for macOS and Windows. Audio Units, VST, VST3 and AAX format. SongKey MK4 is available for just 13,99 |
