| Intelligent processor for your vox with de-esser! Features Process : It will shape your sound with filters, 2 band Dynamic EQ and 3 fixed band EQ. Also, saturation and compression. LED indicator will show processing level. De-Ess : It's de-esser but little hard. Also, it will work as harshness remover. So, it can fully reduce your highs with higher settings. LED indicator will show de-essing level. Output : Clean output Plugin Name : Bypass button UPDATE - v4.0 - 17/11/2021 - Redesigned whole processing sections - New clean GUI - Catalina, Big Sur, Monterey support with M1 processor PATREON |
