Solidtrax releases Analog History soundset for Behringer DeepMind
2021-12-2 23:23| ·¢²¼Õß: 2657387| ²é¿´: 1055| ÆÀÂÛ: 0
ÕªÒª: Solidtrax releases Analog History soundset for Behringer DeepMindSolidtrax has announced the release of a new soundset for the DeepMind (6/12/D) series of synthesizers by Behringer.Analog History feat ...
Analog History features a collection of 84 presets for Behringer¡¯s true analog synthesizer featuring two oscillators with a broad selection of modulation sources.
The sounds we created for you, range from soaring mono leads to punching drums and from warm pads to mesmerizing ambient textures. Together with fat basses, freaky effects, stab and retro poly synth sounds we are convinced that you will inject your compositions with a lot of inspiration.
Most sounds use velocity, mod wheel and aftertouch and make heavy use of the modulation matrix. These presets are created with the ambient, cinematic, synthwave and various sorts of electronic dance music genres in mind. They are created with OS v1.1.2.
In celebration of the new soundset, Analog History is available at a 30% discount until December 31st as part of an extended store wide Black Friday sale. The regular price is 19 EUR incl. VAT.
Use coupon code BF2021 at the checkout to get the discount.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
