United plugins introduce Electrum Core
2021-12-2 11:35| ·¢²¼Õß: vanacoro| ²é¿´: 716| ÆÀÂÛ: 0
ÕªÒª: United plugins introduce Electrum CoreElectrum CoreThe lightweight guitar solutionFor some Electrum, our all-in-one guitar solution is too complex. Electrum Core offers a much more straightforward att ...
Electrum Core
For some Electrum, our all-in-one guitar solution is too complex. Electrum Core offers a much more straightforward attitude. We simply took the Electrum's amazing amp and cab simulations and stripped them from the additional effects to give you a fast way to get straight to the desired guitar tone.
The agile son
Electrum Core may have not inherited all its Mother's features, but it is capable of delivering any style of the guitar sound - from clean guitars to heavy tones. It is meant to serve in quick operations and to get you to the goal as quickly as possible.
Smart input setting
Hit Analyse Input Level button and hit the strings of your guitar as hard as you intend to play. Electrum will set up the input level automatically to find the perfect sweet spot to match your signal's strength with the particular processors' ideal working point. Perfect gain-staging and volume balance helps to get the most out of Electrum.
All amps in one
Any guitar, any style. Electrum provides five guitar amps of different levels of gain and distortion. They share common controls for quick and easy setup with no confusion. We analyzed the most profound amps on the market and created Electrum with these in mind. But we also added several perks, which let you create an amp that is truly yours.
300+ cabinets
Electrum's unique guitar cab simulation brings 16 types of cabinet simulations combined with 21 alterations, over 300 models. Then it lets you add resonances and ambience. And it's no simple IR set, our cabinet produces a great natural sound no IRs can provide.
Upgrade anytime
If you will ever feel like ElectrumCore is not enough, you can always upgrade to the Mother of All Guitar Amps (as we call Electrum, the all-in-one guitar solution) at a special price (EC owners see it after log-in).
Introductory discount 82%
9  instead of 49
https://unitedplugins.com/ElectrumCo...x5yDNRO0Ua4Hro
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
