Analog Obsession ReLife
2021-11-21 08:30| ·¢²¼Õß: bandolero| ²é¿´: 1657| ÆÀÂÛ: 0
ÕªÒª: Analog Obsession ReLifeAnalog Obsession ReLifeAnalog Obsession says that ReLife gives ¡°second life to your lifeless tracks¡±. While we don¡¯t know exactly how it accomplishes this task, that sounds l ...
Analog Obsession ReLifeAnalog Obsession says that ReLife gives ¡°second life to your lifeless tracks¡±. While we don¡¯t know exactly how it accomplishes this task, that sounds like a great idea! Between the gain-compensated input and output knobs lies the shaping section that consists of a one-knob dynamic EQ named SHAPE and a LIFE control that works in mysterious ways to bring your track to life. There¡¯s also a MIX knob that allows you to blend the wet and dry signals.
ReLife is available for Windows and macOS in VST, VST3 and AU formats.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
