DJ Swivel releases Knocktonal Knocktonal: Next-Gen Drum Tuning WATCH THE LAUNCH VIDEO Grammy Award Winning, and multi-platinum producer and mix engineer, DJ Swivel, introduces his fourth plugin, Knocktonal. Knocktonal is a note-based resonance enhancer, allowing users to boost (or cut) resonances as well as their corresponding harmonic overtones. Simply put, Knocktonal allows you to tune your drums without the need for destructive re-pitching of samples. The plugin is equipped with both Additive Resonance, and Subtractive EQ¡¯s, offering complete control over your root notes as well harmonic overtones with up to 30 bands of resonance. It can be used both statically, or dynamically with separate MIDI input channels for both your additive and subtractive EQ¡¯s. Knocktonal also has a built-in limiter so you can push your signal as loud as you want for a smooth clean sound. ⚡ Tune your drums with resonance/harmonics ⚡ Turn kicks into 808s ⚡ Build melodic percussion phrases ⚡ MIDI input for each EQ ⚡ Control over even and odd harmonics Knocktonal can be used to create resonant bass frequencies in kicks, helping glue them to the mix, or even turns your simple kicks into punchy 808¡¯s. You can create harmonic bass layers over drums, or even design percussive lead instruments/melodies by enhancing the upper harmonics of a source signal. Knocktonal offers surgical precision over the sound of your drums in the most musical way possible. Tune your drums with notes, not Hz! We're launching Knocktonal at an introductory price of only $34.50 until the end of the year, so get your free trial today at djswivel.com/products. I hope you guys enjoy the plugin and get as much use out of it as we have! |
