Easy Tambourine - Free Ableton Live Pack
2021-10-26 15:15| ·¢²¼Õß: 5266890| ²é¿´: 1029| ÆÀÂÛ: 0
ÕªÒª: Easily Create Tambourine Patterns by Holding Down a Few Notes!If you want to quickly add a tambourine pattern to your tracks then the Easy Tambourine Ableton Live Pack is for you. I recorded a few dif ...
If you want to quickly add a tambourine pattern to your tracks then the Easy Tambourine Ableton Live Pack is for you. I recorded a few different tambourine hits, ranging from soft to heavy, and placed them in a slick Drum Rack that will help you create exciting rhythms by just holding down a few notes.
Using an Arpeggiator device, you can dial in the rhythm you want with the Arp Macro Control. Then start holding down different combinations of notes. You will instantly get all different types of patterns and accents. Experiment with including some empty pads to create brief rests in your patterns.
Fine tune the sound with EQ controls. Then top it off with some Delay and Reverb.
Making new patterns has never been so easy!
FREE DOWNLOAD - EASY TAMBOURINE ABLETON LIVE PACK
The Music Production Club is a monthly subscription service that delivers a steady flow of new music production tools to your email inbox. You will have access to the Current Download, Live Classes, the MPC Discord Community, the MPC Sample Folder, Bonus Downloads, and Special Offers from partner companies.
The first month is FREE! Cancel anytime, keep everything.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
